Immobilizer location on ecu
Old Jan 14, 2007 | 07:31 PM
vinuneuro's Avatar
Default Immobilizer location on ecu
My ecu failed, so when I get install the ecu i just bought I'm going to have an ecu with the immobilizer. I have had multiple people confirm that I can desolder the immobilizer circuit from the ecu and solder into the new one. Does anyone know the location of this in the ecu? People have done this with the p72/73. Does anyone have pics of the inside of the ecu?
Old Jan 14, 2007 | 08:27 PM
Jim Truett's Avatar
Default Re: Immobilizer location on ecu (vinuneuro)
If it's a P5M it's the daughter board in location HIC1.
Old Jan 14, 2007 | 08:35 PM
vinuneuro's Avatar
Default Re: Immobilizer location on ecu (Jim Truett)
It's a P5P. How different can it be? I have no idea where location HIC1 is .
Old Jan 15, 2007 | 02:29 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">It's a P5P. How different can it be? I have no idea where location HIC1 is .</TD></TR></TABLE>
The board is silkscreened. Look at it closely. There should be a box with HIC1 printed next to it. Worst case, post pictures of it.
Old Jan 15, 2007 | 02:40 PM
vinuneuro's Avatar
How hard do you think it will be to perform this operation in this ecu?
Old Jan 15, 2007 | 06:49 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">How hard do you think it will be to perform this operation in this ecu?</TD></TR></TABLE>
I couldn't possibly answer that without knowing how skilled you are with a soldering iron. For me it's less than a 10 minute job.
Old Jan 15, 2007 | 06:56 PM
mgags7's Avatar
Has anyone considered figuring out if you can just jump a few pins or use some resistors to completely eliminate the immobilizer?
I have never had to deal w/this problem (I have a 4g) but that would make things much simpler
Old Jul 25, 2008 | 11:58 PM
prelude_93vtec's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">Has anyone considered figuring out if you can just jump a few pins or use some resistors to completely eliminate the immobilizer?
I have never had to deal w/this problem (I have a 4g) but that would make things much simpler</TD></TR></TABLE>
x2
Wytek9
Engine Management and Tuning
Apr 19, 2009 02:38 PM
SOHC_MShue
Oct 14, 2002 11:22 AM
