hybrid shifter woes
Old May 15, 2002 | 09:17 AM
SuperCivic's Avatar
Default hybrid shifter woes
ok, since i did my swap..a B16 into my 89 si hatch..i've been having shifter problems. when i did the swap i used hasport mounts and hasport linkage. i put a DC shifter in, and the shift pattern was very quirky, i had to shift down at an angle to get from 1st to 2nd, had to shift at an angle away to get from 3rd to 4th, and had to put the car in 5th and slam it down to get it into reverse. this past weekend i put the stock shifter back in, and although it is still quirky, it's a lot easier to shift. so i'm thinking the shift mechanism inside the tranny might be bent??? anyone have any ideas on this one?? thanks for any help.
Old May 15, 2002 | 09:31 AM
chhuong's Avatar
Default Re: hybrid shifter woes (SuperCivic)
It's the design of the shiftlinkage, i've spoken to quite a few people about this allready!!
Old May 15, 2002 | 09:32 AM
flat-blk-HB's Avatar
I am not sure about the shaft being bent it would be a lot harder to shift if so. Maybe it is just the linkage set up you have
I have HCP linkage and it is kinda wierd too but i have got use to it
Old May 15, 2002 | 10:05 AM
SuperCivic's Avatar
Default Re: hybrid shifter woes (ED6)
so is EVERY b16 hybrid like this?
Old May 15, 2002 | 10:15 AM
raene's Avatar
Mine's not. But the shifter is almost in the dash when it's in 3rd, it's so far forward.
Old May 15, 2002 | 10:24 AM
SuperCivic's Avatar
Default Re: hybrid shifter woes (raene)
which linkage are you using?
Old May 15, 2002 | 10:26 AM
SuperCivic's Avatar
Default Re: hybrid shifter woes (chhuong)
hey SiRReal Racer right?
i haven't tried my SiR linkage yet cuz i tried bending it out, but i don't think it's really worth trying to salvage. when i took the DC shifter out, the stock shifter is a lot better but still not really stock feeling.
Old May 15, 2002 | 11:01 AM
ricodemus's Avatar
I used the stock SiR linkage. shifts are a little rough, but got better when I put my short shifter (neuspeed) in. I'm pretty happy with it now, but 5th is a pain sometimes (not a big deal).
Old May 15, 2002 | 11:04 AM
EP3_05's Avatar
I have the hasport linkage and a no-name short shifter The shift pattern is not awkward. The only thing different is that it is positioned a little farther back. It took some getting used to but now it is fine and easy to shift.
Old May 15, 2002 | 01:16 PM
HumanResource's Avatar
I'm using a copied HCP adjustable **** linkage
It sucks, But from what I 've heard, the other kits aren't any better.
I wanted to try an ITR, but i ran outta time.
From what I heard, these are the best.
Old May 15, 2002 | 01:45 PM
Malgerus's Avatar
raene's is a modified GSR linkage.
Old May 15, 2002 | 01:55 PM
mackymcg's Avatar
Default Re: hybrid shifter woes (89_Y_49)
I used the adj. HCP linkage when I did my swap. At first I used the shifter from the old engine and the top gears would hit the dash, as well as 5th hitting the passenger's knee. I purchased several different shifters (ITR, SI) and found the Del Sol shifter was shorter and bent a little back and towards the driver. With that shifter in now, the position is perfectly stock, just a little lower.
Old May 15, 2002 | 02:12 PM
bees16a's Avatar
Default Re: hybrid shifter woes (mackymcg)
mines fell after shifting gears. I dont know what wrong with mines. It keeps getting loose or the bracket that holds it up, FALLS!!!!!!!!!!! Mine is a modified integra shiftlinkage.................
91SiRX
Jun 10, 2005 07:41 PM
lsvtec101
May 2, 2003 08:17 AM
crxman00
12
Apr 5, 2003 09:26 AM
cleverkellen
Sep 6, 2002 05:56 PM
