What ecu or system do I need?
Old Jan 14, 2007 | 02:44 PM
BLUE EH3's Avatar
Help we my pennies
Default What ecu or system do I need?
We just did my 95 sohc vtec swap into my EK. Im goin to keep my car obd1. I am running till a p75 till i find an other option .. what would be best option, just get a p28 or a apex system? I also plan to go boost next summa. i want to able tune my ecu as far as being able to raise and lower my fuel setting and other goodies for daily driving and track days..
Modified by BLUE EH3 at 1:21 PM 1/18/2007
Old Jan 14, 2007 | 03:48 PM
doood's Avatar
been there done that
Default Re: What ecu or system do I need? (BLUE EH3)
convert to obd1. use a virgin p28. have it socketed and chipped with whatever ems you choose when you decide to boost.
Old Jan 14, 2007 | 04:18 PM
BlueIntegraBoy's Avatar
If you convert to OBD1, you need the P28
Old Jan 14, 2007 | 04:27 PM
schardbody's Avatar
convert to OBD1 with WHATEVER CHIPPED ECU you can find cheapest, and have the program you want to run installed.
Old Jan 14, 2007 | 05:37 PM
Relic1's Avatar
Default Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">convert to OBD1 with WHATEVER CHIPPED ECU you can find cheapest, and have the program you want to run installed.</TD></TR></TABLE>
x2 (as long as it has VTEC control)
Old Jan 16, 2007 | 01:34 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: (Relic1)
bump
Old Jan 16, 2007 | 01:44 PM
doood's Avatar
Default Re: (BLUE EH3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
for what? your questions have been answered.
Old Jan 16, 2007 | 04:37 PM
stock ek's Avatar
Default Re: (doood)
what does p28 and p75 mean ???
Old Jan 16, 2007 | 04:44 PM
skiracer8148's Avatar
Default Re: (stock ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock ek &raquo;</TD></TR><TR><TD CLASS="quote">what does p28 and p75 mean ???</TD></TR></TABLE>
honda Ecu codes
Old Jan 16, 2007 | 05:39 PM
schardbody's Avatar
Default Re: (skiracer8148)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skiracer8148 &raquo;</TD></TR><TR><TD CLASS="quote">honda Ecu codes</TD></TR></TABLE>
actually it refers to ALOT more than that, but in this situation thats what we are talking about. P28, P72, etc etc etc can be talked about when talking about ecu, head, intake manifolds, and many other things.
Old Jan 17, 2007 | 11:50 AM
BLUE EH3's Avatar
Help we my pennies
so there is no point on running a vtec contoller..
Old Jan 17, 2007 | 11:52 AM
B18CivicEH2's Avatar
DONT get a vtec controller..worthless....if you want Vtec to hit at a different RPM...have your ecu chipped and tune.
Old Jan 17, 2007 | 12:10 PM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">so there is no point on running a vtec contoller..</TD></TR></TABLE>
no, it will only lower your power output.
Old Jan 17, 2007 | 12:19 PM
doood's Avatar
whatever ems you choose will take care of that
Old Jan 17, 2007 | 01:01 PM
CALC!_JUST_du_IT!'s Avatar
Ok, so I'm in the market for a chipped p28 that can be tuned with crome or uberdata (the freebies!). Should I just get a virgin ecu, or get a pre-chipped? How do I know if the chipped ecu I'm getting can be programmed with crome or uberdata? Also, if I'm using a programmable ecu and an adjustable AEM cam gear (SOHC), will that be adequate tuning power on a fully built N/A D16Y8 (11.0:1cr, Crower Stage II cam, etc)?
Old Jan 17, 2007 | 01:15 PM
Relic1's Avatar
Default Re: (CALC!_JUST_du_IT!)
slight thread jacking....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CALC!_JUST_du_IT! &raquo;</TD></TR><TR><TD CLASS="quote">Ok, so I'm in the market for a chipped p28 that can be tuned with crome or uberdata (the freebies!). Should I just get a virgin ecu, or get a pre-chipped? </TD></TR></TABLE>
if you can chip the ECU then go with what ever is cheaper. If you can't do it yourself then get one that is chipped all ready.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CALC!_JUST_du_IT! &raquo;</TD></TR><TR><TD CLASS="quote">How do I know if the chipped ecu I'm getting can be programmed with crome or uberdata? </TD></TR></TABLE>
If it's chipped it will run either program (Crome datalogging requires J12 to be removed) It will even Hondata if you really want to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CALC!_JUST_du_IT! &raquo;</TD></TR><TR><TD CLASS="quote">Also, if I'm using a programmable ecu and an adjustable AEM cam gear (SOHC), will that be adequate tuning power on a fully built N/A D16Y8 (11.0:1cr, Crower Stage II cam, etc)?</TD></TR></TABLE>
more than enough. Provided you're talking dyno tuning... A street tune will be ok, but the dyno is the only way to get it right.
If you're shopping for one, I have a few chipped ECUs for sale that would work great for you. Hit me up on IM
Old Jan 17, 2007 | 01:21 PM
THC07's Avatar
Do know this, by removing J12 you cannot smog, i think...
cutting j12 opens full deplux mode, meaning the guy that smogs, cannot do the obd check, which is apart of smog. i say "i think" cuz im not sure if you have to have a obd check with obd1 cars. but it will disable the service plug under the dash.
NM your not even in cali, sorry.
Old Jan 17, 2007 | 01:46 PM
Default Re: (THC07)
I'm in cali... unfortunately. I beyond considering a legitimate smog...
Old Jan 18, 2007 | 08:37 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: (THC07)
just a question when does vtec hit ona p28? i am planning on goin turbo in next summa. wont i need a ecu that i can raise and lower my fuel and other things at low and hi boost
Old Jan 18, 2007 | 08:50 AM
THC07's Avatar
55
Old Jan 18, 2007 | 10:19 AM
.Grimace's Avatar
footwork mastery
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">just a question when does vtec hit ona p28? i am planning on goin turbo in next summa. wont i need a ecu that i can raise and lower my fuel and other things at low and hi boost</TD></TR></TABLE>
you can do this with a chipped p28.
Old Jan 18, 2007 | 11:01 AM
Relic1's Avatar
stock P28 VTEC points...
low load (cruising) 5500
high load (WOT) 4800
a chipped OBD1 ECU can adjust many settings, fuel/ignition/VTEC/boost/trims/etc
A chipped P06 with VTEC parts added works well also. It's also typically cheaper...
Old Jan 18, 2007 | 11:06 AM
BLUE EH3's Avatar
Help we my pennies
how adjust the tune
Old Jan 18, 2007 | 11:07 AM
Relic1's Avatar
chip the ECU, run a program like Crome or Hondata with datalogging and a wideband O2 sensor and adjust the tune.
the_wholesaler
Apr 8, 2014 11:26 AM
GoKOOLjeff
Jan 28, 2009 10:06 AM
rockinthe94LS
Aug 26, 2008 06:25 PM
89silverb16crx
15
Apr 14, 2004 10:02 PM
roc109
Nov 19, 2002 09:06 PM
