93 delsol si brake booster/master cyl/proportion valve work on a 92 eg
Old Jan 14, 2007 | 01:05 PM
t57b18's Avatar
Default 93 delsol si brake booster/master cyl/proportion valve work on a 92 eg
like it say will the delsol si brake booster and master cylinder and proportion valve work on a eg. im doing a 4 wheel disc swap and have the rest of the brakes off of a gsr .let me know if this will work.thanks donny
Old Jan 14, 2007 | 01:20 PM
Rocks03's Avatar
Default Re: 93 delsol si brake booster/master cyl/proportion valve work on a 92 eg (t57b18)
It should work as seening the year of the models. Check your brake line pressure at the proportion valve before you take it out and after you install it in the eg. If they are close to one another then you should be fine.
Old Jan 14, 2007 | 01:45 PM
t57b18's Avatar
some one has to know if it wil work some one help
eggwhite22
Jul 30, 2009 07:06 AM
hYbRid_Eg6
Apr 3, 2009 01:48 PM
CapnKrunch
18
Aug 30, 2007 05:38 AM
NstyGrnHatch
Jul 30, 2005 04:25 AM
SpydiR
Aug 10, 2004 01:36 PM
