93 delsol si brake booster/master cyl/proportion valve work on a 92 eg
like it say will the delsol si brake booster and master cylinder and proportion valve work on a eg. im doing a 4 wheel disc swap and have the rest of the brakes off of a gsr .let me know if this will work.thanks donny
Re: 93 delsol si brake booster/master cyl/proportion valve work on a 92 eg (t57b18)
It should work as seening the year of the models. Check your brake line pressure at the proportion valve before you take it out and after you install it in the eg. If they are close to one another then you should be fine.
93, booster, brake, check, civic, del, honda, install, installing, proportion, proportional, propportion, si, sol, valve
