Need A Throttle Cable For My B16 Motor
I have a 1989 Honda CRX Si. Dropping In A 88-91 B16A1 SiR1 motor, does anyone know the throttle cable w/ bracket I need? n where to get it? im tryin to get all the missing pieces asap. cuz i need my car. lemme know. thnx. my aim is WhiteBoi4m562
you can use your stock si throttle cable, just make a bracket. go to home depot and get some flat stock and bend it and drill some holes. much cheaper than buying a new cable
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">you can use your stock si throttle cable, just make a bracket. go to home depot and get some flat stock and bend it and drill some holes. much cheaper than buying a new cable</TD></TR></TABLE>
yeap
yeap
cheaper but time consumin..if you make $20ph at ur job and it takes you an hour tomake that bracket you might as well just buy a new cable....thats what I did and it fits perfect...no "rigging" look with a teg cable
for $25 you can get off your *** and buy a new cable from the dealership. plus then your swap doesn't look ghetto as hell with a homemade bracket
actually it looks pretty nice its aluminum, its adjustable, I had the piece of aluminum just sitting around took about 10 minutes to make so whats the problem? should I spend $25+dollars or do it for free.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s10cky »</TD></TR><TR><TD CLASS="quote">You can also use the ITR throttle cable, its what im using for my setup.</TD></TR></TABLE>
me too. get a p30 cable bracket if you like the aluminum look or go with a p73 bracket if you want the bronze look. the p30 and p73 brackets are identical except for color.
