clutch balancing
Old Jan 14, 2007 | 10:01 AM
tigueremalo's Avatar
Default clutch balancing
am pretty confused with my clutch pedal i adjusted it so it can closer to the floor but it looks like by me tighting the clutch cable what i did is make the clutch higher and not closer to the floor of the car so to make it closer to the floor is it making it tighter or loosing it
Old Jan 14, 2007 | 01:46 PM
fourthgenhatchB17's Avatar
Default Re: clutch balancing (tigueremalo)
If u tightened the adjusting nut and the result was opposite from what u wanted (brought the clutch engagement higher on the pedal), one would think to try and loosen the nut right?
Old Jan 14, 2007 | 02:23 PM
Crx Jimmy's Avatar
not sure of what you are saying but if you want the clutch to engage closer to the floor loosen it , if you tighten it it will make the clutch engagement farther from the floor
Old Jan 14, 2007 | 02:29 PM
Default Re: clutch balancing (Crx Jimmy)
alright then thanks you guys!!!!!!
Haarstad
Jun 24, 2012 09:50 PM
Kermit EK
Jan 29, 2003 03:02 PM
