gauge lights stopped working.....
Old Jan 13, 2007 | 09:49 PM
B18Sleeper's Avatar
Default gauge lights stopped working.....
ok so i turned on my car today and went to turn on my headlights and usually the gauges light up with the headlights but it didnt. the tach speedo and fuel/temp gauges work just not the lighting. how can i fix this?
Old Jan 13, 2007 | 09:51 PM
MAX PAYNE's Avatar
Default Re: gauge lights stopped working..... (B18Sleeper)
Dimmer or fuse.
Just do it !
Old Jan 13, 2007 | 09:52 PM
Tjames8864's Avatar
Default Re: gauge lights stopped working..... (MAX PAYNE)
fuse
Zeusfire69's Avatar
Depending on the car, there is usually a separate fuse for the guage lights...
Old Jan 13, 2007 | 09:55 PM
MAX PAYNE's Avatar
Hey, I forgot to ask. Did you recently install a cd player or anything electrical?
Old Jan 13, 2007 | 10:08 PM
B18Sleeper's Avatar
well its not the dimmer and the fuse i dont know which one it would be does anyone have an idea? thanks
Old Jan 13, 2007 | 10:09 PM
B18Sleeper's Avatar
oh yea the car is a 2000 honda civic si
Old Jan 13, 2007 | 11:39 PM
FMUNK's Avatar
Have the same issue on Stephanie's old SFWD 2000 SI.
I put a uncut engine harness and a uncut dash harness in the car, because someone else hacked it all up. But for some reason the Guage cluster light will not work.
When I plug a dimmer in.......smoke comes out then the fuse blows.
Possibly the three OLD dimmers I had were all bad???????
Maybe something in the Cluster is shorted....causing it to burn up dimmers???
It would not surprise me considering the hackjob dash harness that WAS in it.
This car only has 40,000 miles on it so I would like to keep an ACCURATE cluster in the car
This car is for sale BTW, PM for details.
Old Jan 14, 2007 | 10:17 AM
B18Sleeper's Avatar
Default Re: gauge lights stopped working..... (FMUNK)
oh man thanks for the offer but i ran out this morning and got a new 7.5amp fuse and replaced that in my fuse box and now they work....but i was wondering is there anyway to tell how accurate the needles are? or get them redone to be more accurate or do u need just to go get a whole new cluster?
Old Jan 28, 2007 | 05:44 PM
bin_dizzle's Avatar
hey guys I have a similar problem,
just bought a 94 Si and the inspection failed because of the same thing w/ the cluster & a/c lights...
except: Everything went back to normal when it was freezing cold, then the lights went dead again after ~10 minutes of driving.
Question: is it a loose connection? if so, where would it be? any help would be appreciated, thanks
Old Jan 28, 2007 | 08:43 PM
B18Sleeper's Avatar
Default Re: (bin_dizzle)
i would say a loose connections somewhere a sort in ur wiring harness...location is untelling.
ricanxplaya
Apr 18, 2012 05:17 PM
185Kaccord97
Nov 12, 2007 01:42 PM
CaptainQuirk
Jul 11, 2007 12:09 PM
Bserieskllr
12
Aug 1, 2004 01:38 PM
