anyone know about h22 revhard tubular turbo manifold
I saw this manifold and was wondering if anyone is running it and if so then is it ac/ps compatable.
If not then could some giveme a quick explanation about what makes a manifold a/c compatable. Is it the placement of the wastegate or do other parts get in the way? Can parts be trimmed (like brackets, motor mounts) to make it ac/ps compatible? or can a civc half size radiator solve this problem?
I was searching for hrs and cannot find an answer so any/all input would be greatly appreciated.
Thanks
https://honda-tech.com/zerothread?id=1312310
Thanks
revhard does not make tube manifolds for h series, unless thats really old imo, why not use there cast h22 mani? its good for 400whp some peeps have used it up to 550whp but they converted the wg to 46mm. feel free to pm for pricing on RH parts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">revhard does not make tube manifolds for h series, unless thats really old imo,</TD></TR></TABLE>
Thats what i thought too....I think they make a cast manifold for the h22 but the do have a tubular manifold for the h23. http://www.revhard.com/index.php?c=manifolds&s=2
http://www.turbo-kits.com/prelude_turbo_kits.html
check out the 6th one down (stage 3). It says for H22 - and it lists the Rev Hard tubular manifold
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">revhard does not make tube manifolds for h series, unless thats really old imo, why not use there cast h22 mani? its good for 400whp some peeps have used it up to 550whp but they converted the wg to 46mm. feel free to pm for pricing on RH parts. </TD></TR></TABLE>
I know of a H22 tube mani that is rev hard T4 flange with 44mm wastegate and makes over 600whp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">i know an easy way to get to the bottom of this, i'll just call myles
i;ll post what he says.</TD></TR></TABLE>
Umm ok but I don't think there is anything to "get to the bottom of"
i;ll post what he says.</TD></TR></TABLE>Umm ok but I don't think there is anything to "get to the bottom of"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by md23vtec »</TD></TR><TR><TD CLASS="quote">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by md23vtec »</TD></TR><TR><TD CLASS="quote">Umm ok but I don't think there is anything to "get to the bottom of"
yes there was, and i got to the bottom of it, the h22 tube turbo mani is no longer in production.
they will however make 1 if and only if you order there stage 3 turbo kit.
</TD></TR></TABLE>yes there was, and i got to the bottom of it, the h22 tube turbo mani is no longer in production.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">yes there was, and i got to the bottom of it, the h22 tube turbo mani is no longer in production.
they will however make 1 if and only if you order there stage 3 turbo kit.</TD></TR></TABLE>
You seem so devoutly proud, but what did you get to the bottom of? Whatever it is your at the bottom of md23vtec was already there.
they will however make 1 if and only if you order there stage 3 turbo kit.</TD></TR></TABLE>You seem so devoutly proud, but what did you get to the bottom of? Whatever it is your at the bottom of md23vtec was already there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94Vtecluder »</TD></TR><TR><TD CLASS="quote">You seem so devoutly proud, but what did you get to the bottom of? Whatever it is your at the bottom of md23vtec was already there.
hey ******* moron, listen, first i questioned that it was not a RH mani and if it was it was no longer in production, then someone said it was and showed a picture, then i called myles to confirm wether or not they ever made one and if its still in production, i then posted the answer. so thats what i got to the bottom of. expletive man i didnt know trying to help was a ******* crime. i happen to know myles so do a million other people, i thought i'd use that to figure this out, whats the problem?
</TD></TR></TABLE>hey ******* moron, listen, first i questioned that it was not a RH mani and if it was it was no longer in production, then someone said it was and showed a picture, then i called myles to confirm wether or not they ever made one and if its still in production, i then posted the answer. so thats what i got to the bottom of. expletive man i didnt know trying to help was a ******* crime. i happen to know myles so do a million other people, i thought i'd use that to figure this out, whats the problem?
Relax man just busting your *****
But I defiantly didn't get the kit just the manifold only.
they will however make 1 if and only if you order there stage 3 turbo kit.</TD></TR></TABLE>Relax man just busting your *****
thats cool bro, ball busting is
with me but yeah they used to make it until recently. im sure the'll make one if you harass them. they do still have the jig for it afterall. i think they just stopped cause it was time consuming to make and there was not a huge demand for it, just speculating here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">how much did it cost?</TD></TR></TABLE>
around 350 give or take I dont remember exactly but defiantly under 400
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">oh, well howmuch did they go for? whos this jason hunt you speak of?</TD></TR></TABLE>
I am not sure how much they went for. Jason is just another slow guy from maryland
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">Some ricer that thinks he's the king of the streets.</TD></TR></TABLE>
Took the words out of my mouth
just found out they still make an equal length tube mani, the one they no longer make is a shorty tube mani, just wanted to clear this up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">just found out they still make an equal length tube mani, the one they no longer make is a shorty tube mani, just wanted to clear this up.</TD></TR></TABLE>
No comment
No comment
