crx si question
Old Jan 13, 2007 | 08:14 PM
crx noob's Avatar
Default crx si question
This may sound like a stupid question. What are the differences between a 90 model HF and Si. Would it be hard to make a HF a Si because some one might give me a Si motor. Could someone clear this up For me Thanks.
Old Jan 13, 2007 | 08:15 PM
h224thgensedan's Avatar
motor goes right in. No wiring required both cars are allready mpfi.
Old Jan 13, 2007 | 08:21 PM
crxnj's Avatar
Default Re: crx si question (crx noob)
like the guy says,they're both mpfi so the engines will interchanged no problem,and the si ecu will plug in no problem..
as far as differences there are some,like the si has a sunroof,bigger front hubs,stronger larger axles,shorter geared tranny,sunroof,rear interior compartment,black/grey interior instead of blue?,nicer seats imo,alloy wheels,the 90-91 si has disc brake in the rear,etc,etc,etc.....
hf has a better turning ratio though,lighter weight,both models have factory lips,hf has a factory shiftlight,
Theres's some more differences.
Old Jan 13, 2007 | 08:40 PM
gospeedgo1's Avatar
Default Re: crx si question (mr.speaker)
the hf also had a smaller gastank, and i think it didnt have a rear swaybar and it also had a smaller front swaybar if i remember correctly. no rear wiper also on the hf
Old Jan 13, 2007 | 08:51 PM
harmonator84's Avatar
Default Re: crx si question (gospeedgo1)
First of all let me welcome you to HT. Second of all the best thing to do when you first come to HT is read the FAQ. It has pretty much every answer you need. Lets see here I will help you out with your first question.
What are the differences between a 90 model HF and Si?
Here is the link that would help you.
https://honda-tech.com/zerothread?id=650219
It has it displayed right on the FAQs.
I hope this could help and Good luck.
Old Jan 14, 2007 | 07:51 PM
crx noob's Avatar
what about a dx to a si what changes will need to made to the motor.
Old Jan 15, 2007 | 05:01 AM
crxnj's Avatar
Default Re: (crx noob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx noob &raquo;</TD></TR><TR><TD CLASS="quote">what about a dx to a si what changes will need to made to the motor.</TD></TR></TABLE>
dx has 2 injectors vs. the hf/si 4 injectors..so you'll have to convert the dx to multi point fuel injection, there's a great writeup here. http://fourthgenhatch.net
Old Jan 15, 2007 | 05:05 AM
crx noob's Avatar
thanks this helps so much
Old Jan 15, 2007 | 05:09 AM
janz3n's Avatar
this thread is retarded.. try searching . or go to faq.
Old Jan 15, 2007 | 08:35 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (janz3n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n &raquo;</TD></TR><TR><TD CLASS="quote">this thread is retarded.. try searching . or go to faq. </TD></TR></TABLE>
Was your post even necessary at all?
Old Jan 15, 2007 | 09:01 AM
janz3n's Avatar
Default Re: (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">
Was your post even necessary at all?</TD></TR></TABLE>
i helped the guy didnt i? these noobs are too lazy to look around before posting questions that have been covered many a times
Old Jan 15, 2007 | 12:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n &raquo;</TD></TR><TR><TD CLASS="quote">i helped the guy didnt i? these noobs are too lazy to look around before posting questions that have been covered many a times</TD></TR></TABLE>And I am sure at one point you were the same way!
hotwater
28
Jul 19, 2008 06:36 AM
EK FLY
Oct 8, 2005 07:36 AM
lilneep16v
Feb 14, 2005 05:21 AM
NomadMan
36
Mar 29, 2004 07:03 PM
JBk24crx
Oct 13, 2003 07:34 PM
