Main Bearings
Old Jan 13, 2007 | 06:11 PM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
Default Main Bearings
Well I took apart a GSR block, supposedly hasn't been disassembled before and I matched the code of the crank and the block to find the bearing color. The codes resulted in having Brown (C3), Black(D3), Green(C2), Black(D3), Blue(D4) bearings. When I took out the actually bearings, there were Brown, Black, Green, Black, GREEN bearings. So instead of a BLUE bearing from the code of the crank/block, there was a green bearing for Main Journal #5. I need to order a set of bearings from my dealership and as soon as they come in, I will plastigauge them to double check the clearances. Should I order Green or Blue bearings for Main Journal #5? I'm thinking about ordering blue because that was the original code of the block/crank. Let me know what you guys think, thanks.
Old Jan 13, 2007 | 07:27 PM
Default Re: Main Bearings (JDM turbo DC)
Old Jan 14, 2007 | 01:20 AM
anyone?
Old Jan 14, 2007 | 06:14 AM
speedworks's Avatar
i would order what the codes come out to be and check clearances from there.
Old Jan 14, 2007 | 08:21 AM
Default Re: Main Bearings (speedworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedworks &raquo;</TD></TR><TR><TD CLASS="quote">i would order what the codes come out to be and check clearances from there. </TD></TR></TABLE>
thanks, bump for more opinions
Old Jan 14, 2007 | 11:12 AM
GREEN or BLUE ??
Old Jan 14, 2007 | 01:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM turbo DC &raquo;</TD></TR><TR><TD CLASS="quote">GREEN or BLUE ??</TD></TR></TABLE>
Old Jan 14, 2007 | 06:59 PM
biotech0123's Avatar
Nuff said dude.
Old Jan 15, 2007 | 05:32 PM
91SiZ6's Avatar
You already need to buy one set of Greens for #3 so use that set to check #5 as well. Ordering accordingly.
Old Jan 15, 2007 | 06:20 PM
Default Re: (91SiZ6)
well i talked to my dealership and they cant except any refunds on special orders. so hopefully they will all work out
Old Jan 15, 2007 | 06:42 PM
tha_badguy's Avatar
anyone have experience ordering main & rod bearings from majestic...
is this correct?
A is Blue
B is Black
C is Brown
D is Green
E is Yellow
F is Pink
G is Red
& why do they have 2 different sets of std piston rings?
is there a difference between the 2?
also does anyone know whats included in their bottom end gasket kit?
this is for a b16a2 btw
Old Jan 15, 2007 | 09:20 PM
91SiZ6's Avatar
Default Re: (JDM turbo DC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM turbo DC &raquo;</TD></TR><TR><TD CLASS="quote">well i talked to my dealership and they cant except any refunds on special orders. so hopefully they will all work out</TD></TR></TABLE>
It's only $16 for another set if the clearances aren't what you want.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tha_badguy &raquo;</TD></TR><TR><TD CLASS="quote">anyone have experience ordering main & rod bearings from majestic...
is this correct?
A is Blue
B is Black
C is Brown
D is Green
E is Yellow
F is Pink
G is Red
this is for a b16a2 btw</TD></TR></TABLE>
Yes, that's the correct bearing order. Honda updates parts a lot so you'll often see a few different listings for the same item. There might be another reason though, so give them a call. The OEM gasket kits include every gasket and seal for the engine.
Old Jan 16, 2007 | 12:41 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91SiZ6 &raquo;</TD></TR><TR><TD CLASS="quote">
It's only $16 for another set if the clearances aren't what you want. </TD></TR></TABLE>
$16? where do you get them for that price?
Old Jan 16, 2007 | 12:49 AM
91SiZ6's Avatar
http://www.AcuraAutomotiveParts.org
My bad, it'll actually be $20.
Old Jan 16, 2007 | 12:55 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91SiZ6 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.AcuraAutomotiveParts.org
My bad, it'll actually be $20.</TD></TR></TABLE>
yea, well i get it for $18, but $16 per set would save me a good couple bucks when i buy all the bearings. thanks anyways.
teamitr
Dec 13, 2006 10:32 AM
totalimpact
Nov 16, 2005 12:01 PM
milton
May 8, 2005 02:09 PM
The Jacko
Feb 17, 2005 11:01 PM
