How to put a d16y8 into 96-98 civic dx...little help
Old Jan 13, 2007 | 05:24 PM
1clean_ Ej's Avatar
Default How to put a d16y8 into 96-98 civic dx...little help
I have a 97 civic dx. The y7 just gave up a few weeks after I bought it. I think it was all dew to a big right foot of the buddy I got the car from! But anyways I need to know all the small things that im not going to expect. Im puting a d16y8 in and trying to keep the old ECU so I bought a buddy club vtec controller so vtec will switch over. And im tryin to keep the cost down so the stock y7 harness is going to be used thats where I really need all the help iev been told that it all plugs right in I mean atleast thats what I thoght. but im leavin it up to yall for help..thanks!
Modified by 1clean_ Ej at 7:05 PM 1/13/2007
Old Jan 13, 2007 | 06:22 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: How to put a d16y8 into 96-98 civic dx...little help (1clean_ Ej)
Old Jan 14, 2007 | 02:01 AM
Katman's Avatar
You should really try your hardest to get a 96-98 EX ecu mostly because of 2 things - the IACV and VTEC.
Yes, you could use a VTEC controller to make VTEC work, but you'll be lacking the VTEC fuel and timing maps that an EX/D16Y8 ecu has, and what a DX ecu doesn't have at all.
2nd, the Y8 engine use a 2-wire IACV whereas your Y7 engine uses a 3-wire IAC. The Y7 ecu looks for a 3-wire IACV. So if you try using your DX ecu on a Y8 engine, you're going to get a check engine light for the IACV because the Y8 doesnt use a 3-wire IACV. BTW, the IACV on a Y7 engine is integrated on the throttlebody; the Y8 IACV is seperate and located on the backside of the intake manifold. Altho, an AUTO Y8 intake manifold uses a 3-wire IACV!
A couple solutions you can try would be this:
1) What you can do is, and I'm not sure if this will work 100%, is to use your DX throttlebody on the EX engine. You might have to swap out the throttle pulley for the EX throttle pulley, oh and you'll need a EX throttle cable.
2) if you wind up going with teh VTEC controller route, just use your complete DX intake manifold on the EX head, it will bolt up.
Old Jan 14, 2007 | 12:16 PM
1clean_ Ej's Avatar
Default Re: How to put a d16y8 into 96-98 civic dx...little help (Katman)
Thanks guys! I think I mite go on a little parts hunt befor trying to to put it in. What are the #'s on the 96-98 ex ECU is it a p2p? Becues I know the 99-00 ex harness is a little diffrent and will not work like the 99-00 ex ECU but I don't know what the #'s are on the 99-00 ecu?
Old Jan 14, 2007 | 01:02 PM
1clean_ Ej's Avatar
I need a 96-98 ex engine harness fast someone please help me out I need it fast no ride ! and I need a 96-98 ex vtec ECU I think its a p2p not sure but I need a harness and a ECU fast.....help!!!
Modified by 1clean_ Ej at 10:41 AM 1/15/2007
Old Jan 16, 2007 | 10:21 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1clean_ Ej &raquo;</TD></TR><TR><TD CLASS="quote">I need a 96-98 ex engine harness fast someone please help me out I need it fast no ride ! and I need a 96-98 ex vtec ECU I think its a p2p not sure but I need a harness and a ECU fast.....help!!!
You should post this in the wanted section in the classifieds forum...
Take a peek at my ecu part number legend here:
http://ecu.ff-squad.com/ecu.info.pn.htm
Old Jan 16, 2007 | 11:33 AM
1clean_ Ej's Avatar
Thanks dude not real good at the honda-tech thing yet! but ill try it tho.
Modified by 1clean_ Ej at 5:00 PM 1/18/2007
Vincent Torres
Jan 4, 2018 04:38 PM
BSBACKER15
13
Sep 23, 2014 02:30 AM
djjosehernandez
Sep 14, 2008 06:12 AM
zeroracerh
Oct 16, 2003 06:43 PM
