oil leak on spark plug tube...
hi, my friend just give ma his 91 civic lx and i find out that the spark plug tube have engine oil all over, i was thinking of the spark plug seal .. but .. any of you have any idea??? ??
but don't u think that's a little too much from that little oil seal ... and way before myfriend's eg have the same problem, and i changed it for him and still getting the sameproblem .. .is there any other cause .. for the leak ...
since you've got to take off the valve cover anyway you might as well get the whole kit,it comes with valve cover gaskets,o-rings,washers,and grommets.
Hopefully this solves the problem,if it doesnt then it might be coming from the o ring(s) under the rocker arms,,which was a pain in the *** to do.
Someone just posted same question like 2 weeks ago .... Id replace the valve cover gasket and the 4 spark plug tube seals also replace the pedistol O rings
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 408wdy »</TD></TR><TR><TD CLASS="quote">thats the only way oil can get in there, through that o ring that sits in the v/c.</TD></TR></TABLE>
no its not.. it can leak right at the bottom aswell. thats what yours looks like, mine does the same thing. you can try the v/c gasket kit but i really dont think thats going to stop anything.. if you cant see any oil leaking down then its your rocker arm asembly O ring that goes betweeen the rocker arm assembly and the head right at the bottom of that tube.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salman »</TD></TR><TR><TD CLASS="quote">you have to do it else, spark will to leak,</TD></TR></TABLE> english please?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.speaker »</TD></TR><TR><TD CLASS="quote">since you've got to take off the valve cover anyway you might as well get the whole kit,it comes with valve cover gaskets,o-rings,washers,and grommets.</TD></TR></TABLE>
im having the same problem im leakin oil in the spark plug #3 and 4 i dunno but i think it the seaL plus i dont wanna drive it if drive it while its still leaking what can happan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks »</TD></TR><TR><TD CLASS="quote">, or the rocker o rings</TD></TR></TABLE>
i love you
try changing the valve cover gaskets first if that doesnt work. its your rocker o rings.
i love you
advanced auto, autozone, napa.
They sell the whole kit. Make sure you tell them you want the kit that has the spark plug seals. I got the whole kit for $20. It came with valve cover gasket, spark plug seals and valve cover nuts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n »</TD></TR><TR><TD CLASS="quote">
i love you.</TD></TR></TABLE>
Thank you
, I love lamp
Thank you
, I love lamp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdx860 »</TD></TR><TR><TD CLASS="quote">lol found my problem had too much </TD></TR></TABLE> too much oil?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mysicivic1991 »</TD></TR><TR><TD CLASS="quote">i had the same problem too, what i did was change the gasket that came with the O rings. i bought at auto zone it was pretty easy.</TD></TR></TABLE>
lol yes, i think we figured that out a long time ago.. but iv found that most of the time its the rocker arm o rings/seals.
janz3n is right, i had the same problem with my car
its not the vavle cover gasket or the tube seals, i replaced both of those before i found out that it was O ring that seals between the head and the rocker assy. its not real hard to fix, just take off the rocker arm assy. and be careful how you put it back together
get a haynes or chilton service manuel(very helpful)
premo_si
Jan 23, 2008 08:57 PM
gixxer6
Oct 29, 2002 01:10 PM
