taking out power steering
Old Jan 13, 2007 | 05:13 PM
invisible's Avatar
Default taking out power steering
started doing my swap and need to remove or disconnect the power steering so i can pull the motor out. what all do i need to take out?
picture for refference. http://www.streetsports.com/Ph...e.jpg
Old Jan 13, 2007 | 08:52 PM
invisible's Avatar
Default Re: taking out power steering (.Huey)
bump
Old Jan 13, 2007 | 08:55 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
should be like 2 12mm holding the pump plus the adj and 2 10mm on top for the line..and move it
Old Jan 13, 2007 | 09:02 PM
invisible's Avatar
Default Re: taking out power steering (Throwdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Throwdown &raquo;</TD></TR><TR><TD CLASS="quote">should be like 2 12mm holding the pump plus the adj and 2 10mm on top for the line..and move it </TD></TR></TABLE>
when remove the lines will fluid pour out?
Old Jan 13, 2007 | 09:05 PM
Throwdown's Avatar
yes get something to drain it into (cup,etc) i also turn the steering wheel a few times ....when letting it drain
Old Jan 13, 2007 | 09:14 PM
actionfigure's Avatar
why do you wanna get rid of your PS?
I have no ps and sometimes I wish I did.
Old Jan 13, 2007 | 09:15 PM
Throwdown's Avatar
Default Re: taking out power steering (actionfigure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Huey &raquo;</TD></TR><TR><TD CLASS="quote">started doing my swap and need to remove or disconnect the power steering so i can pull the motor out. what all do i need to take out?
Old Jan 13, 2007 | 09:25 PM
invisible's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Throwdown &raquo;</TD></TR><TR><TD CLASS="quote">yes get something to drain it into (cup,etc) i also turn the steering wheel a few times ....when letting it drain </TD></TR></TABLE>
coo thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by actionfigure &raquo;</TD></TR><TR><TD CLASS="quote">why do you wanna get rid of your PS?
I have no ps and sometimes I wish I did.</TD></TR></TABLE>
i really don't want to but ill have it disconnected till i can find the right ps brackets and such to make it work.
dut
Jan 5, 2007 07:07 AM
99delsol
Sep 14, 2006 09:09 PM
avivo
Aug 28, 2006 04:37 PM
mugen92acintls
Feb 4, 2004 04:05 PM
BoostedSixthGen
Aug 12, 2003 03:33 AM
