EF8 axles w/ hydraulic gearbox??
Old Jan 13, 2007 | 05:12 PM
FutureCivic's Avatar
Default EF8 axles w/ hydraulic gearbox??
Hey guys
I just bought a jdm ef8 sir, still has the original b16a motor, but the gearbox was damaged and unuseable.
I am currently sourcing a S80 or S4C box, im wondering if the axles will be compatible with these?
Old Jan 13, 2007 | 08:35 PM
crxnj's Avatar
Default Re: EF8 axles w/ hydraulic gearbox?? (FutureCivic)
Yes your stock ef8 axles are compatible with those hydro trannys as long as you keep the stock halfshaft you have now,,also you should think about changing the axle seal on the tranny to a cable type seal so it doesnt leak. maybe just use the old seal from the old damaged tranny on the new tranny if it's in good shape.
Old Jan 14, 2007 | 04:31 AM
Default Re: EF8 axles w/ hydraulic gearbox?? (mr.speaker)
Sounds good, thanks for your help!
1bar_ek
May 18, 2008 04:44 PM
93 ls
Aug 1, 2006 03:30 PM
hondatuner20
Mar 19, 2006 04:36 PM
gatesrex91
Dec 17, 2003 08:52 AM
