civic 91 question
Old Jan 13, 2007 | 03:42 PM
Bc3's Avatar
Bc3
Default civic 91 question
anybody have pic how to put b16 hydro tranny into 91 civic?
Alli
Old Jan 13, 2007 | 03:46 PM
crxnj's Avatar
Default Re: civic 91 question (Bc3)
do you want to put in a clutch master cylinder and run the hydro lines? or do you want an adapter that lets you use the stock cable to activate the clutch? if its the later one then look here http://innovativemounts.com/Sh...41000
Old Jan 13, 2007 | 03:57 PM
Bc3's Avatar
Bc3
Default Re: civic 91 question (mr.speaker)
i am bulding a b16 turbo/nos motor from a 99 with hydro transmission and i will need a car and i am thinking about to put it in a 91 as they are just 8xx kg and all of the 91 use cable transmission so i was wondering how to put th hydro transmission into the car :D sorry about my English i am from Iceland
Old Jan 13, 2007 | 03:59 PM
crxnj's Avatar
did you check that link?
Old Jan 13, 2007 | 04:03 PM
Bc3's Avatar
Bc3
yes can i just buy this and use the hydro transmission with the cable :S it cant be that easy ha ha
Old Jan 13, 2007 | 04:05 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bc3 &raquo;</TD></TR><TR><TD CLASS="quote">yes can i just buy this and use the hydro transmission with the cable :S it cant be that easy ha ha </TD></TR></TABLE>
Yeah,it is.
If you have some fabrication skills you can make something like it yourself also..It doesnt have to be fancy,as long as it works and is safe
Old Jan 13, 2007 | 04:09 PM
crxnj's Avatar
there are pic in these threads
https://honda-tech.com/zerothread?id=1818108
https://honda-tech.com/zerothread?id=1785112
Bc3's Avatar
Bc3
Ok thats nice but do you know if i will need to move the motor mounts to let b16 fit into 91?
Old Jan 13, 2007 | 04:11 PM
crxnj's Avatar
im not sure about the cars in iceland...Did your car originally come with a b16 or did it come with a D16 engine? if its the D16 engine then you'll need a mount kit,custom made shift linkage and rear mount t-bracket from a 91 integra...you can order the complete mount kit,shift linkage and hydro adapter from innovative if you want..dont order from them specifacly shop around for better deals
Old Jan 13, 2007 | 04:19 PM
Bc3's Avatar
Bc3
the car i took the motor out was a 96 with orginaly b16 motor
Modified by Bc3 at 5:49 PM 1/13/2007
91akira
Jul 2, 2009 05:07 PM
91civichatchCrX
Feb 2, 2006 10:34 PM
jpnucrx
Oct 21, 2005 06:56 AM
racingant
Jul 7, 2005 08:15 AM
