Guesstimate the whp/tq of this setup...
I'm planning on having a B18B built with my Si head put on it and a Golden Eagle LS/VTEC Kit. I'm just going to be running it NA this way for awhile until I decide on a Turbo Setup. So basically I'm just kinda wondering where I'll be at for whp and wtq with this NA setup for the time being? Thanks! Here's the setup:
Laskey Built B18B1
Benson Sleeved
Benson Balanced and Micropolished Crankshaft
CP Pistons and Rings
Eagle Rods
ACL bearings
OEM Oil Pump
Lower Gasket Set
Blueprinting and Assembly
Laskey Built B16 Head
PortFlow Port and Polish
Titanium Dual Valve Springs and Reatiners
SuperTech Stainless Steel Nitride Coated Valves
3 Angle Valve Job
Golden eagle LS/VTEC Kit
Surfacing
What do you guys think?
Laskey Built B18B1
Benson Sleeved
Eagle Rods
ACL bearings
OEM Oil Pump
Lower Gasket Set
3 Angle Valve Job
Surfacing
CP 9:1 Pistons and Rings. And I believe the bore is 81.5mm...
Haha! I'd love to. Unfortunatley, there aren't any Dyno's around here for a long ways and my weeks are too busy with work to go and most are closed on the weekends... sonner or later I'll get it to a Dyno for Tuning but until then I'm just looking for what you guys think it'll make for power.
Murk 'EM
Apr 27, 2009 08:15 PM
97itr86
Nov 4, 2004 05:06 PM
