JDM vtec solinoids have no pressure switch... question
Old Jan 13, 2007 | 02:15 PM
Kirk@SyndromeAuto's Avatar
Default JDM vtec solinoids have no pressure switch... question
so jdm vtec solinoids dont have a pressure switch so my question is I have a usdm ecu is it going to just throw a code then? right now i have a jdm in car harness and a jdm engine harness. My ecu that im currently running is a obd 2 jdm ecu so im not getting a code for the vtec solinoid. but my car is a obd 1 so its throwing a code for secondary o2 sensor. I want to connect my old obd1 ecu but i need a harness but wont it throw a code since its a usdm ecu for the vtec solinoid not being plugged in?
please help
Old Jan 13, 2007 | 05:33 PM
DC2 Mang's Avatar
Default Re: JDM vtec solinoids have no pressure switch... question (Kirk@SyndromeAuto)
yes it will throw a code because there is not pressure switch plugged in
your best option would be to get a usdm vtec solenoid or get your ecu chipped so it wont check for the vtec pressure switch
Old Jan 14, 2007 | 12:30 AM
Default Re: JDM vtec solinoids have no pressure switch... question (DC2 Mang)
well i have a usdm vtec solinoid but how would i wire it up if there are no wires already there since i have a jdm harness in my car.
Old Jan 14, 2007 | 06:35 AM
lVlemphizStylez's Avatar
your other option is to get a Chipped OBD1 ECU (which you will have to do anyway if youre seriously wanting some performance out of your car) You can disable the vtec pressure switch via the ECU
Old Jan 14, 2007 | 10:14 AM
Default Re: JDM vtec solinoids have no pressure switch... question (lVlemphizStylez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">your other option is to get a Chipped OBD1 ECU (which you will have to do anyway if youre seriously wanting some performance out of your car) You can disable the vtec pressure switch via the ECU</TD></TR></TABLE>
ya shiet tats going to cost alot :/
Old Jan 14, 2007 | 10:20 AM
Not really...And youre going to have to do it regardless at some point if you do any major modification to the car (Cams, Turbo, Bottom End building)
sh!ft
Sep 1, 2009 07:03 PM
prime-R
16
Apr 11, 2009 05:33 PM
mikehawk
Oct 26, 2008 03:41 PM
ek9800
Apr 4, 2005 12:42 AM
spyderracing
15
Oct 21, 2004 05:49 PM
