changing trans. fluid with (synthetic)?
Old Jan 13, 2007 | 01:14 PM
allricedout's Avatar
Default changing trans. fluid with (synthetic)?
okay i bought some amsoil 10w 30 motor oil fully synthetic , should i take it back and just get regular motor oil instead? i have searched and found nothing
Old Jan 13, 2007 | 01:30 PM
Ls_dx's Avatar
Default Re: changing trans. fluid with (synthetic)? (allricedout)
use honda mtl or redline mtl... reg motor oil doesnt have all the friction modifiers that the trans oil has...get honda or redline
Old Jan 13, 2007 | 01:46 PM
has anyone else had experience with this ?
Old Jan 13, 2007 | 01:47 PM
I Shot 50 Cent's Avatar
Found nothing!?!? Whoa..
https://honda-tech.com/zerothread?id=1838312
https://honda-tech.com/zerothread?id=1530060
https://honda-tech.com/zerothread?id=1474240
https://honda-tech.com/zerothread?id=916887
And those were just threads from the FIRST page of the 4 I got back from searching. The ones I just posted were ones that had a decent amount of posts and information.
After reading those, you shouldnt have ANY more questions.
Old Jan 13, 2007 | 02:23 PM
i have searched my guts out and found little on synthetic... is AMSOIL synthetic 10w 30 okay, or will the syn. screw up the syncros?
Old Jan 13, 2007 | 02:25 PM
I've heard nothing about Amsoil or any fully synthetic MTF screwing up syncros. I believe you'll be perfectly fine man. Alot of people actually SWEAR by Amsoil.
Old Jan 13, 2007 | 02:26 PM
schardbody's Avatar
geez, synthetic or conventional, doesnt matter, NEITHER were designed for the tranny, so why spend more than you have to just to do it wrong???
in other words: use honda MTL, synchromesh, or redline.
Old Jan 13, 2007 | 02:33 PM
philosofy1's Avatar
can't go wrong with honda MTF!
Old Jan 13, 2007 | 02:37 PM
^^^^ yes i know. but does nobody know if synthetic 10w 30 motor oil will screw up my tranny? i already have it and need to know if ppl have used similar oils in thier trannys?
Old Jan 13, 2007 | 02:44 PM
philosofy1's Avatar
Default Re: (allricedout)
honda says, if honda MTF is not available, then to use 10w30. but this is kind of a last option.
Old Jan 13, 2007 | 04:27 PM
Ls_dx's Avatar
Default Re: (philosofy1)
a last option, tempory type situation<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">honda says, if honda MTF is not available, then to use 10w30. but this is kind of a last option.</TD></TR></TABLE>
use the ams oil in your engine, run honda or red line or a mixtgure of both in your tranny...
93eg2james's Avatar
honda genuine ftw!!
Old Jan 13, 2007 | 05:49 PM
schardbody's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout &raquo;</TD></TR><TR><TD CLASS="quote">^^^^ yes i know. but does nobody know if synthetic 10w 30 motor oil will screw up my tranny? i already have it and need to know if ppl have used similar oils in thier trannys?</TD></TR></TABLE>
it will not do any more harm than conventional motor oil will, if thats what you mean.
Old Jan 13, 2007 | 07:53 PM
^^^ well can anyone confirm this.... if that is the case i will be glad to put the amsoil in and let everyone know how it reduces the notchiness.
Old Jan 13, 2007 | 08:09 PM
my_slow_civic's Avatar
I've ran 10 30 synthetic for over 40k miles in my Si. Thats all I used in my EG, and my EF. Just recently switched to redline mtl. No difference there either.
Old Jan 13, 2007 | 08:12 PM
^^^ nice info, sounds like im going synthetic motor oil then
Old Jan 13, 2007 | 08:43 PM
THC07's Avatar
if you care enough to make this thread you probly want the best. right?
GM syncromesh FM. Hands down the best fluid for our hondas.
in my opnion and im sure many others, from best to good.
GM syncromesh FM
pennzoil syncromesh
purple royal
redline
honda mtf
sand0
Oct 31, 2012 03:11 AM
enoker001
Transmission & Drivetrain
Jun 25, 2009 11:09 PM
Mashka
Honda S2000
Sep 3, 2007 01:50 PM
DraginTeg93
Feb 19, 2007 11:09 AM
Wayne_Curr
Nov 9, 2005 11:38 PM
