window
Re: window (bbhockey19)
probably the little teeth of the window where the motor works are all mest up thats how mine where so i purchased a new 1 for like only 80 bucks
just go here enter car model and year
Re: window (95ProjectEJ1)
heres the link bro
http://www.carpartswholesale.com
you cant also look around and find really cheap stuff pz
Re: window (slayerfromhell212)
Not trying to be a dick but if you search up on this, it's posted several times a week and you can find all your anwers on this topic there. However to try to help you when mine came off the track I took the door panel off and got the window back on the track, then ran the window to go up and down to see where the window was jumping out, then I loosened the clamp that holds the bottom of the window to get it seated perfectly then slowly but evenly I bent the metal part of the track in the same direction the window would pop out of (towards the inside of the car or towards the outside, whichever way it was going) Anyway, once I got it all set in, I put some powder graphite in the track and spayed some heave silicone lubircant in and I haven't had a problem since and that's been since August of 06, and I smoke like a chimney so my windows are always going up and down. Hope this helps.
