HELP IN CENTRAL FLORIDA!
I have a drivers side motor mount that is constantly rocking around and moving, I can feel it when I hit bumps and I've gone through like 5 drivers side axles since my b16 swap. Every shop I take it to tells me that some movement is normal, but since I am running solid motor mounts I think that's probably the cause of my axle breakage and the feeling of something bouncing around when I hit a bump.
What I need help with, is a shop in Central Florida, or really anywhere in Florida that has experience with swapped EFs and that I can trust to resolve my issue before it costs me anymore money.
SUGGESTIONS, PLEASE!
p.s. The problem is not the mount itself, I had the same experience with my hasports mounts that I sold and with the new ones (Innovative).
Modified by Jesterian at 5:14 PM 1/16/2007
Why don't you sell the innovative mounts and put back Hasports? And what driving conditions are you breaking axles under?
<-- In CFL every other weekend.
I have the right axles, but I am driving on some shitty dirt roads that cause the car to bounce around quite a bit. Did either of you have the name of a shop?
Oh, and the Innovatives are noticeably smother than the Hasport mounts when it comes to vibration.
Also, my passenger side axle has been the same through like 4 drivers side replacements, so it's not how I'm driving. I baby the **** out of my car because I know there's something wrong.
Modified by Jesterian at 4:52 PM 1/15/2007
did you take the dust sheild out of the steering knuckle?
If not that can cause your axels to bind up and eventually break.
Check all your nuts and bolts make sure that they are all tight?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef-hatchcrap »</TD></TR><TR><TD CLASS="quote">did you take the dust sheild out of the steering knuckle?
/.</TD></TR></TABLE>
Yes yes, I've checked EVERYTHING. The dust shield is off, there's no axle binding. The drivers sound mount has considerable movement, despite having the nuts and bolts tightened. It just doesn't fit right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jesterian »</TD></TR><TR><TD CLASS="quote">Oh, and the Innovatives are noticeably smother than the Hasport mounts when it comes to vibration.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jesterian »</TD></TR><TR><TD CLASS="quote">
The drivers sound mount has considerable movement, despite having the nuts and bolts tightened. It just doesn't fit right.</TD></TR></TABLE>
Sometimes you have to sacrifice a little comfort for a decent life span in a component. Do you like in Polk county, or deep Osceola, those are the only place I can think of that have dirt roads in such disrepair that they would be owning you. In Kissimmee, I can occasionally find the energy to go a wee bit off rally style racing on my friends farm and no problems here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">
Like I said, the hasports had the exact same issue and I just recently switched to Innovative mounts. The hasports fit exactly the same. I can feel my engine bouncing around when I hit a bump, and I can feel a huge lurching sensation when I shift. It's been that way since I had the hasport mounts.. Do you know any reputable shops in this area?
</TD></TR></TABLE>Like I said, the hasports had the exact same issue and I just recently switched to Innovative mounts. The hasports fit exactly the same. I can feel my engine bouncing around when I hit a bump, and I can feel a huge lurching sensation when I shift. It's been that way since I had the hasport mounts.. Do you know any reputable shops in this area?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jesterian »</TD></TR><TR><TD CLASS="quote"> Do you know any reputable shops in this area?</TD></TR></TABLE> Any that I would trust my money with, I can't say that I do OTHER than CFT. Did you break axles before you swapped on the roads?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote"> Any that I would trust my money with, I can't say that I do OTHER than CFT. Did you break axles before you swapped on the roads?</TD></TR></TABLE>
Yeah, this is an ongoing issue since before I switched from Hasport to Innovative. I actually switched because I thought the hasport mount had somehow broken and that was causing my problem. But the Innovative fits just as loose and vibrates around like a ************. I'm talking really damn lose, despite having tightened everything possible.
What's CFT?
What's CFT?
I was actually considering using washers placed flush with mount bushing on the inside to make it fit tighter. Unfortunately I don't have any tools at my disposal and I have limited technical expertise..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma »</TD></TR><TR><TD CLASS="quote">which mount is moving around??</TD></TR></TABLE>
My bad, it is the driver's side. I clarified that in the original post.
hmm....initially i assumed that the mount bracket must have gotten jacked up and widened during a swap....but now i'm thinking that tightening the bolt would close up any gap that might exist
so is the engine moving up & down on the driver's side? like the bolt hole itself got bored out?? have you watched the motor while a friend mashes the gas once or twice?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma »</TD></TR><TR><TD CLASS="quote">hmm....initially i assumed that the mount bracket must have gotten jacked up and widened during a swap....but now i'm thinking that tightening the bolt would close up any gap that might exist
so is the engine moving up & down on the driver's side? like the bolt hole itself got bored out?? have you watched the motor while a friend mashes the gas once or twice?</TD></TR></TABLE>
Actually I just lowered the idle down to the point that the motor was stuttering a bit and I could see the mount moving around. I know the problem is the mount bracket, I just don't know how to fix it.. I tried tightening the bolt but that did very little.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 »</TD></TR><TR><TD CLASS="quote">i'll be in cocoa tomorrow morning at 8am. if you want to drive up to the cocoa historic district i'll try to help.
pm me if you want my cell #.</TD></TR></TABLE>
PMed.. Come on people, I have yet to even see someone mention a shop. Honestly, anywhere in Florida is fine as long as they're skilled and reputable.
well is the mount tight on the block? under the timing cover
with out seing it im not going to be much help but theres not much need to find a shop theres more than enough people on this site that know as much and if not more than someone at a shop and if there willing to look at it for you take the help
i don't know ware these guys are to you but have you tried DFE ENTERPRISES 904-378-4480 there in JACKSONVILLE or AD Fabrication 561-208-1683 in Pompano Beach and last one i have is Titan Motorsports 407-277-8423 in Orlando and i would also get rid of the innovative mounts if you braking axles there is something more wrong then a lose mount i have seen guys drive around on broken mounts and not have that problem but if any of these guys are near you they should be able to tell you whats wrong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Golden Eagle »</TD></TR><TR><TD CLASS="quote">i don't know ware these guys are to you but have you tried DFE ENTERPRISES 904-378-4480 there in JACKSONVILLE or AD Fabrication 561-208-1683 in Pompano Beach and last one i have is Titan Motorsports 407-277-8423 in Orlando and i would also get rid of the innovative mounts if you braking axles there is something more wrong then a lose mount i have seen guys drive around on broken mounts and not have that problem but if any of these guys are near you they should be able to tell you whats wrong </TD></TR></TABLE>
Like I said, I was breaking axles before the innovative mounts. Thanks a lot for the suggestions though!
