:Repairing Shift Knob
Old Jan 13, 2007 | 11:34 AM
Dunc's Avatar
BCICAN
Default :Repairing Shift ****
What happened: I have the B&M Pro Edge shifter. Originally I had a Sparco **** on there but didn't like it that much so I put the stock **** back on there. I couldn't get the sparco **** off easily so I had to chew up the threads on the shifter to get it off. Now the stock **** can rotate a little so at around 90mph it'll vibrate and it's just annoying.
My Thought: Can I fill the stock **** with JB Weld (this would be the only bit of JB Weld on the car, and it's hard to bring myself to using it haha), and then also put it on the threads of the shifter? I was thinking about doing that and when it hardens I would tab out the shifter that way there are threads of the right size on both the shifter and ****. Do you guys know of any other methods? Thanks
Old Jan 13, 2007 | 05:14 PM
BlueIntegraBoy's Avatar
Default Re: :Repairing Shift **** (Dunc)
Take a dye and rethread the shifter.
Old Jan 13, 2007 | 05:31 PM
youdontknowmeeither's Avatar
if i was going to put anything on there instead of fixing the threads, i'd use locktite.
Old Jan 13, 2007 | 05:33 PM
Dunc's Avatar
BCICAN
Yea that's what I was planning on doing. It's just the the threads on the stock **** I think are slightly chewed up because of the shifter's threads. Do you think filling it with JB Weld (to basically give myself a new beginning) would actually work on the ****? I didn't know if that would stick to the inside of the shifter or not.
Old Jan 13, 2007 | 07:12 PM
opeth13's Avatar
driver slower.
Old Jan 13, 2007 | 07:47 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: :Repairing Shift **** (opeth13)
judging by the vehicle stated in your signature, i would assume you are not too low on funds....so in my opinion instead of ghetto rigging it just pop for a new shifter and ****, and make sure you don't make the same mistake twice
Old Jan 13, 2007 | 08:37 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
yeah that's my vote, new shifter and ****, or at least use a die and re-thread the shifter.
Old Jan 14, 2007 | 02:54 AM
god.loves.ugly
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opeth13 &raquo;</TD></TR><TR><TD CLASS="quote">driver slower.</TD></TR></TABLE>
Old Jan 14, 2007 | 11:14 AM
Dunc's Avatar
BCICAN
Default Re: :Repairing Shift **** (GRAF-FITI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">judging by the vehicle stated in your signature, i would assume you are not too low on funds....so in my opinion instead of ghetto rigging it just pop for a new shifter and ****, and make sure you don't make the same mistake twice</TD></TR></TABLE>
Yea it is for the car in my signature, so I can't really say it's a budget build haha. I just didn't see any need to pull the shifter out and everything just for a slight vibration that only happens around 85-90. You make a good point though, maybe I'll just buy a new OEM **** and a new shifter.
Actually what I might do is order the new stuff so it's done right and then just try my idea out for the hell of it. If it works then I could make a simple write up or something since I'm probably not the only person in the world with that problem.
Modified by Dunc at 6:35 PM 1/14/2007
Old Jan 14, 2007 | 02:16 PM
RS'R''s Avatar
you're right, you aren't. the previous owner of the transmission i bought for my rs had an ebay short shifter installed. i don't know why but he cut it even shorter, so i have very little thread left... and it rattles like hell at certain rpms. tell me how it worked out when you're done.
NACvicSi
Free Stuff
Aug 13, 2009 03:11 PM
PatrickGSR94
Jan 24, 2009 04:24 AM
B16Jacques
Sep 20, 2008 09:15 AM
exclusive_vtec
May 19, 2004 08:21 PM
TSAngry
Feb 19, 2004 09:12 PM
