Problems/Questions building my engine
Old Jan 13, 2007 | 11:09 AM
TheLastSpartan's Avatar
Default Problems/Questions building my engine
Working on a B18a block/B16 head.
I haven't been able to work on my engine awhile and the last thing we did was complete the bottom end (ARP rod bolts/PR3 pistons/etc). Well it's been awhile and I was going to finish putting on the head today but when I looked in the cylinder walls, there was some rust! It wasn't as bad as it could been, but the top/upper lip of the cylinders developed some rust.
I was just wondering if it would be okay to continue with it or should I find a new block.
The rust isn't bad but you can tell it's developing.
Also, after placing in the crankshaft, greased up and everything, it was kinda hard to rotate the crank. It'll get 'stuck' halfway... It can rotate all the way but I don't know what is causing it from fully rotating smoothly. Is it normal or is something worn out?
Old Jan 13, 2007 | 11:59 AM
ToeJam's Avatar
Default Re: Problems/Questions building my engine (TheLastSpartan)
A picture would help but..
It sounds like the rust has just begun to build up. If that was the case, I would recommend a hone job with a light coat of oil afterwards.
concerning your block, did you plastiguaged? Did you torque within spec?
Old Jan 13, 2007 | 12:22 PM
d16dcoe45's Avatar
Default Re: Problems/Questions building my engine (toekneevwj)
Take some WD-40 or Pb-Blaster and rub it into the rust with a paper towel--that should get rid of most of it. I would say it will be fine, unless its deep and goes into the sleeve.
1ndigo_1ntegra
Engine Machining & Assembly
Sep 19, 2018 10:19 AM
Bonestock98GS
Nov 4, 2010 04:57 PM
MrToasty
Jul 6, 2009 05:54 PM
P12 EG6
12
Nov 20, 2008 09:37 AM
jdmoptiontune
33
Apr 12, 2008 07:44 AM
