type R idle to high, no check engine light on
Old Jan 13, 2007 | 10:53 AM
hotroddb8r's Avatar
Default type R idle to high, no check engine light on
i just recently did a type R swap, but it idles to high like at 1300 to 1500 i don't know what it is, there is no check engine light. the motor has headers, j's racing intake, ctr crank pully, and a chipped p28. It was the same with my other motor an ls v-tech, but the ls v started to do it after i installed an integra type R intake manifold. need help!
Old Jan 13, 2007 | 11:07 AM
RTW DC2R's Avatar
Default Re: type R idle to high, no check engine light on (hotroddb8r)
maybe you just have too much
Old Jan 13, 2007 | 11:09 AM
MiamiEJ1's Avatar
Default Re: type R idle to high, no check engine light on (RTW DC2R)
give the motor back
Old Jan 13, 2007 | 11:19 AM
Parada's Avatar
Default Re: type R idle to high, no check engine light on (MiamiEJ1)
I love how theres a 3-4 post period that the op has to get over without blowing up on someone, before he/she gets a straight answer, my fav part of h-t, seeing wether the newbs can take the heat.
Old Jan 13, 2007 | 11:54 AM
LunchboxZT's Avatar
Default Re: type R idle to high, no check engine light on (Parada)
Wait, here's redundant post #4
Maybe you should get a lighter weight flywheel?
Old Jan 13, 2007 | 01:46 PM
andyt's Avatar
Is your timing right?
Valves adjusted?
Old Jan 13, 2007 | 04:31 PM
SuperSteve737's Avatar
Check your throttle cable, it may be too tight and slightly opening the TB
Old Jan 13, 2007 | 06:07 PM
hotroddb8r's Avatar
yea thats ture i do got to much v-tech its crazy when it kicks in at 4800 its loud!!!!!!
Old Jan 13, 2007 | 08:48 PM
Parada's Avatar
HAHAHA... sorry, the thaught of too much v-tec is humerous
HondaGuy02
May 3, 2008 09:13 AM
DesolationsAngel
Jun 9, 2007 02:30 AM
gtec28
May 18, 2007 07:13 AM
HybridGSR1
Oct 6, 2003 07:32 PM
