Need Help on Car Idlering
Any body help me figure out why is my 92 honda civic si with a d16z6 motor, it keep on idlering very bad soon as it get started about 1min, and it won't stop at all. I have flush out my cooling system, but its not the problem, wat els could it be.....and just one more thing why is my cooling fan switch is not working at all i have change out the thermostat to a 180 degree, and still can not find out whys it not working........pplz HELP............thank you
when it stops running you need to check if your getting spark and fuel...
sometime the coil and the fuel pump go bad.. they will run fine till they warm up
Gremlins don;t like the cold!
jdm_bones
Apr 24, 2006 02:57 PM
ill phil
Aug 23, 2003 06:18 PM
