Wipers wont return to park?
Old Jan 12, 2007 | 08:54 PM
Spence's Avatar
Default Wipers wont return to park?
Hey guys im wondering why my wipers on my newly purchased car wont return to the parked position. Currenlty they stay in a goal post style. I recently replaced the icu, stalk, and wiper motor but this did not fix this. What could be wrong?
Spence
Old Jan 13, 2007 | 08:30 AM
bart2546's Avatar
Default Re: Wipers wont return to park? (Spence)
Will they return to "park" after running them in any of the "on" positions..what I mean is if you run them in intermitent, high, low any of those, when you turn it off will it go back to park or do they go in the "goal post" position all the times. I'm thinking maybe it's the switch itself on your steering column. If you've already replace that, then I'm not really sure what it could be since you said you did the motor. There's only so many parts to the windsheild wiper system.
Old Jan 13, 2007 | 10:48 AM
HomeDepotMade's Avatar
Default Re: Wipers wont return to park? (bart2546)
i remember my whipers got stuck while i was driving and all i did was press it down and it worked again. np anymore?
Old Jan 13, 2007 | 07:40 PM
Spence's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bart2546 &raquo;</TD></TR><TR><TD CLASS="quote">Will they return to "park" after running them in any of the "on" positions..what I mean is if you run them in intermitent, high, low any of those, when you turn it off will it go back to park or do they go in the "goal post" position all the times. I'm thinking maybe it's the switch itself on your steering column. If you've already replace that, then I'm not really sure what it could be since you said you did the motor. There's only so many parts to the windsheild wiper system. </TD></TR></TABLE>
yes it dosent matter what i put them on interm, low, or fast they all park in the upright, my switch i got at the junk maybe its bad but i doubt it
Old Jan 14, 2007 | 06:17 AM
speedworks's Avatar
probably the arms under the cowl panel out of time. turn the wipers off, remove the wiper motor, put the wipers in the parked position, then reinstall.
Old Jan 14, 2007 | 12:29 PM
Spence's Avatar
Default Re: Wipers wont return to park? (speedworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedworks &raquo;</TD></TR><TR><TD CLASS="quote">probably the arms under the cowl panel out of time. turn the wipers off, remove the wiper motor, put the wipers in the parked position, then reinstall.</TD></TR></TABLE>
Im going to go try this today ill let you know whats up
IBriaIN
Acura TSX
Nov 15, 2008 04:51 AM
Fliplm0de
Sep 29, 2005 06:13 AM
CRFAB04
Welding / Fabrication
Mar 8, 2005 09:22 AM
projektCRX
15
May 2, 2004 07:07 PM
b16ahybrid
16
Feb 3, 2004 05:52 PM
