HELP Fujita CAI INSTALL
I am literally installing this right now, please help if you can.
I have taken off the stock airbock and forgot that I needed to put it into 5th gear, however, the it won't go into 5th gear at all no matter what I try. I read post that people's intake are blocking it but I don't have the stock or new intake in at all.
1. Can someone please show me a picture of what may be blocking it?
2. Also, does it matter if I have my car jack up? Does it matter?
3. Also, how in the world do you take off the batter tray, I gotten off all the 12mm bolts already but there are 2 "tie wraps" like thing holding on the - and + wires to the tray.
Thanks in advance
Thanks in advance
1. remove the cai from the throttle body so you have some space and put your car in 5th gear. then put the cai so that it does not hit the shifter thing.
2. i dont think it would matter if you have it jacked up or not
3. check under the battery tray, there should be some more bolts under there maybe you missed those.... also remove the terminals if your trying to take the battery out
hope this helps
hope this helps
well the problem is that there is no intake in the car right now, just empty bay.. I just can't get into 5th gear. THe stock intake has already been taken out and i haven't install intake to TB yet.
DO you know what else can be the cause?
when i did my intake i thought i couldnt get into 5th gear but it was just that 3rd and 5th
are really close together and i was trying to put it into the place where a 7th gear would
go.....
go.....
lol, no, something is most definatley blocking it. Since there is no intake in the TB at all, I'm stunned....to tell u the truth, im getting a bit paranoid
Also, do you know hwo to remove the battery wire that is attach to the metal battery bracket?
Thanks for the reply though
Here are some links...hope that helps
http://www.ivtecdaily.com/rsx/mods/cai.html
http://performance.clubrsx.com/prsxinjencai.html
http://forums.clubrsx.com/show...a+CAI
ArchAngel Sabastian
Aug 31, 2001 12:53 AM
