LS-VTEC, CRX, OBDO-OBD1- injectors not working
Just finished LS-VTEC. Inserted chipped P28 and started car. Car won't run. Injectors click one time and then no more. Have ignition. Changed dizzy's, same result. pulled OBD0 conversion off, tried OBD0LS ecu- nothing. Used D15B OBD1 Ecu, nada. Somebody help me the expletive out here!!!!
What ECU, Injector, distributor combination are you running?
You'll have to have one of the following combinations to work:
OBD0 ECU
OBD0 Injectors
OBD0 Dizzy
or
OBD1 ECU
OBD0 injectors with resistor box or OBD1 injectors without resistor box
OBD1 Dizzy
OBD0 ECU
OBD0 Injectors
OBD0 Dizzy
or
OBD1 ECU
OBD1 Dizzy
EK FLY
Jul 25, 2006 09:55 AM
