ECU codes pissing me off
Old Jan 12, 2007 | 05:28 PM
sahtt's Avatar
Default ECU codes pissing me off
Already searched here and http://www.team-integra.net/se...ID=34.
My car is a 94 4dr GSR. Dead stock besides alarm.
I got a maint. light when I started the car to come home from work today. I've rebuilt lexus v8 engines and done VGTT swaps on 300zx twin turbos, but I can't get the goddamn codes to work on this little honda for the life of me.
My car has no green unit as usually mentioned, and has 2 blue connectors dangling slightly from under the pass dash. I tired 17 different ways of 'connecting' the two wires in the 2 prong blue connected, and can NOT get the ECU into the code mode. Jammed paperclips up it, tried everything.
Here is what I do.
Get 2-prong blue connector.
Insert paper clip into brown/black wire spots/prongs.
Turn car into ignition position 'II' [ON].
Not doing jack ****. Can someone give me a clue as to what I'm doing 'wrong'? Is there some special way/placement of putting in the paperclip? Or what is wrong with the car causing this not to work? I've got a 300 mile drive coming up on Sunday and I'll be paranoid as hell if I don't at least know what the light is on for.
I'll end up cutting the connector off and physically connecting the two wires at this rate.
Modified by sahtt at 6:51 PM 1/12/2007
Old Jan 12, 2007 | 05:37 PM
no2unenolife's Avatar
i just used a piece of wire and connected the ends into the blue connector, maybe the paper clip isn't making a good connection
Old Jan 12, 2007 | 05:42 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: ECU codes pissing me off (sahtt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sahtt &raquo;</TD></TR><TR><TD CLASS="quote">I got a maint. light when I started the car.</TD></TR></TABLE>
did you get a "maintenance required" light or the actual check engine light?
Old Jan 12, 2007 | 05:50 PM
sahtt's Avatar
Default Re: ECU codes pissing me off (GRAF-FITI)
maybe we are getting somewhere afterall..
I haven't had the car long and just realized it was indeed a 'maint reqd' light. Didn't realize there was a difference until now.
I subconciously figured it would still go into code mode without a CEL, other OB1 cars I've owned all gave an 'all clear' code, usually designated as code '55'.
Old Jan 12, 2007 | 05:52 PM
sahtt's Avatar
It may have to do with the fact I haven't reset it since changing my oil. I believe the maint. light comes on in a series of blinks when you start the car relating to this. It had been doing it for the last couple weeks. Perhaps if you don't reset it after a given amount of time it simply stays on?
I glanced under the steering column today looking for the 'reset button' and did not locate that either.
Old Jan 12, 2007 | 05:55 PM
jthm's Avatar
If it is your service maint light then you do just need to reset it. It is a small square button under the steering column. It is akward to find the first time.
Old Jan 12, 2007 | 05:58 PM
sahtt's Avatar
Default Re: ECU codes pissing me off (jthm)
Yeah I'm continuing the trend and being an idiot today. 10 sec search and I confirmed what I suspected.
I crack my rear windows 1-2" on each side to get a breeze in. On the way home from work going about 60mph I heard my jacket slide off my seat and look up just in time to see my 1216 net paycheck that was under it go out the back window into a sea of cars. No telling how long that will take to get fixed.
Thanks guys.
Old Jan 12, 2007 | 06:01 PM
jthm's Avatar
Thats what direct deposit prevents
Old Jan 12, 2007 | 06:40 PM
numbnuts22715's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sahtt &raquo;</TD></TR><TR><TD CLASS="quote">Yeah I'm continuing the trend and being an idiot today. 10 sec search and I confirmed what I suspected.
Thanks guys.</TD></TR></TABLE>
oh man, that suckkkkks.
but atleast you got the car stuff figured out
eg6madness
Engine Management and Tuning
May 27, 2009 04:24 PM
eg6madness
19
Nov 19, 2007 11:02 PM
ceLtic*
Apr 15, 2005 02:38 PM
Slatelude
Oct 27, 2003 03:28 PM
93EH6
Jan 30, 2003 09:11 PM
