Clutch horse power rating?
Why? How much you got?
It's really a matter of the clamping force of the pressure plate; but the clutch disc itself needs to be good friction material.
Well i'm not sure but i've got plans to put 17:1 compression pistoins in my f22a6 and do a few more major internal mods so i've got no ideal what i'll have
Clutches are generally rated for torque, not horsepower. They kinda don't care what RPM they're spinning, but they DO slip or fail based on how much torque they're transmitting.
Having said that, I don't know the answer - how much torque it can handle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nxr87 »</TD></TR><TR><TD CLASS="quote">i've got plans to put 17:1 compression pistoins in my f22a6 and do a few more major internal mods so i've got no ideal what i'll have </TD></TR></TABLE>
interesting. what fuel are you planning to run on this build??
yeah I am a little weary of 17:1 since 13:1 is high for pump gas.
But the accord clutch is the same as the h22. and people are running tons of hp and tq on stock clutch. honestly as long as you are n/a I think you will be fine.
When you start getting high hp/tq slicks and high rpm launches you might have a problem.
What pistons do you plan on using?
Ross or wiseco and it's def not going to be running on pump gas it'll be an alcohol mixed with 110 and as far as fuel mods andthing i can i'll need it all to tune it right
