H22 injectors???
if they are to tight then it would be pointless. Try this http://homemadeturbo.com/tech_....html
i dont think these injecors will fit is there any other brand or anyone who has switched injectors what ones did yall go with and did u need to change any o rings or fittings??
i have no idea why they wont fit .. do you need to twist and put a lot of purssure on them or wat cuz mine just arent goin in and for everone that has done it do u use the stock bottom o ring and that bottom plastic spacer??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lshatch59 »</TD></TR><TR><TD CLASS="quote">i have no idea why they wont fit .. do you need to twist and put a lot of purssure on them or wat cuz mine just arent goin in and for everone that has done it do u use the stock bottom o ring and that bottom plastic spacer??</TD></TR></TABLE>
Are you sure they are the dsm 450s? I know quite a few people that have used those. I have them ready to go in mine. I've already test fitted them.
