OBD0 vs. OBD1 B16 distributor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wheelman-CZ »</TD></TR><TR><TD CLASS="quote">Does anybody know whats the diferent between OBD0 and OBD1 distributor for B16 engines?
Thank you!</TD></TR></TABLE>
The internal gears have a different number of teeth. They're not compatible.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bambam »</TD></TR><TR><TD CLASS="quote">
The internal gears have a different number of teeth. They're not compatible.</TD></TR></TABLE>
my friend tried converting an obd0 to obd1 and didn't work. it would cut the RPMs off at 3k.
they have different color wires. The wires are all the same except for one. OBD-0 has a <U>Large White </U>wire Where as the OBD-1 has a <U>Yellow/Green </U>wire. The code for the 88-91 b16 (OBD-0) should be TD02U, and the 92-95(OBD-1) should be TD42U.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P.O.S_DA9 »</TD></TR><TR><TD CLASS="quote">they have different color wires. The wires are all the same except for one. OBD-0 has a <U>Large White </U>wire Where as the OBD-1 has a <U>Yellow/Green </U>wire. The code for the 88-91 b16 (OBD-0) should be TD02U, and the 92-95(OBD-1) should be TD42U. </TD></TR></TABLE>
You can't use an OBD1 distributor with and OBD0 ecu and vice versa.
I dont want to use it, I just wnat to know whats the diference and if is possible to rebulit OBD0 to OBD1.
Thanks everybody for answers!!!
crazyef8
10
Apr 20, 2009 09:44 PM
ej8
Jan 27, 2005 10:56 PM
