Transmission problem?
Old Jan 12, 2007 | 01:00 PM
JDN169's Avatar
Default Transmission problem?
Hey guys,
Im looking into buying (another) CRX on the cheap. Here's what the guy has to say about the "problem":
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">i replaced the driver side rotar and axle and hub assembly because i grounded down the splines in my old hub. but now when i go into gear my wheels wont spin, so im assuming i knocked the axled gears are knocked out of alignment... clutch maybe.. who knows but i need a DD
If worst comes to worst i have a spare tranny and axles in the garage, just wondering what you guys may think the problem is.
thanks!
Jacques
Old Jan 12, 2007 | 01:02 PM
jlicrx's Avatar
Default Re: Transmission problem? (JDN169)
i would say that the axle is not all the way into the transmission - it needs to go in until the little clip engages the differential side gear
Old Jan 17, 2007 | 01:43 PM
gp70hs's Avatar
Default Re: Transmission problem? (jlicrx)
Best guess, you are not looking at a transmission problem, per se.
From what you described, this car was working until the hub was destroyed. Replacing the half shaft and the hub would not create a problem in the transmission. It's not in, not seated, or something, on one side, or the other. I'd be very surprised if it was anything other than a misinstalation issue when he replaced the half shaft and the hub. Something wasn't done correctly, or he used an incorrect replacement.
pit.crew
Mar 16, 2012 10:35 AM
1998_Lude
Sep 9, 2008 12:47 PM
dthug
Feb 14, 2007 03:43 PM
Turbocivic94
Apr 11, 2006 06:53 PM
Crimson_Tide
Jan 1, 2006 10:22 AM
