ecu isse
Uhm...for the OBD0 ECUs all you need to do is pull the carpet back and look at the blinking light in the center of the ECU...count the blinks and thats the code...short blinks = 1 long blinks = 10
on the OBD0 cars you read the codes directly from the ECU by looking at the flashing red LED - you don't need to jumper anything - if it has more than one code, the ECU will flash a number of times for the first code, pause and flash a number of times for the 2nd code, pause, etc. - it will keep repeating the codes until you reset the ECU
ef_you_again
Mar 17, 2005 11:14 PM
