95 civic ecu problem
Old Jan 12, 2007 | 11:11 AM
jztt's Avatar
Default 95 civic ecu problem
I just put a new head on my 95 civic ex and she won't start now. I got fuel but not sure if I have spark or not. I tried to check ecu for codes but I get nothing out of it. My srs light flashes but check engine light does nothing. Factory service manual says if no check engine light when connector is shorted you have a bad ecu.
Does anyone know where to get a ecu and how much it should cost?
Old Jan 12, 2007 | 11:15 AM
fmrprojects's Avatar
Default Re: 95 civic ecu problem (jztt)
you sure you put all the grounds on and that the firing order is in the correct order
Old Jan 12, 2007 | 11:24 AM
jztt's Avatar
I'm pretty sure I will double check though. But shouldn't I get a flashing check engine light when I short the connector
Old Jan 12, 2007 | 04:07 PM
jztt's Avatar
Default Re: (jztt)
Mesm23
Jun 13, 2017 09:11 AM
Blainet96
May 27, 2015 03:28 PM
cuseikan
Aug 18, 2008 01:26 PM
1320king
Jul 22, 2007 12:32 PM
petrv
Jan 4, 2002 07:37 AM
