ticking sound
Old Jan 12, 2007 | 10:42 AM
gkwan's Avatar
Default ticking sound
Hello,
My car has developed a ticking sound and it only happens when the car is in gear and moving. Only happens in gears 1,2,3, and 5 I have not noticed the sound in 4th gear. it sounds like the wheel of fortune wheel ticking. I have a feeling its coming from my transmission, but people have told me otherwise, any ideas what I should check for?
also when i rev it in neutral the car sounds fine.
Thanks!
Old Jan 12, 2007 | 11:33 AM
Lewdin' Incognito's Avatar
Default Re: ticking sound (gkwan)
Ever had the axles changed? Very probable it's the CV joint(s).
Other possibilities: tranny, wheel bearing, ball joint.
I would lean more toward the tranny, axles, or bearing since you said it does it when you move. The others would most likely be heard in curves and hitting bumps.
Old Jan 12, 2007 | 12:08 PM
trickeng's Avatar
Default Re: ticking sound (Lewdin' Incognito)
try getting on a dyno so you can load the car while in one spot and listen.
darkwater_ghost
Transmission & Drivetrain
Jan 3, 2013 11:31 AM
88 civic ef
Jul 18, 2006 02:08 AM
jdmazm
Apr 28, 2005 07:57 PM
TheHater
15
Jan 22, 2003 06:46 PM
JDM Accord
Oct 13, 2002 02:48 PM
