Removing axles during swap
Old Jan 12, 2007 | 08:16 AM
kinkyintegra's Avatar
Default Removing axles during swap
Im about to pull out my motor in my em1 from the bottom but i was just wondering....how do i take out the axles without removing other things? As im lifting the car away from the engine, just knock them out of their slots and them pull them out? will that work?
Old Jan 12, 2007 | 08:20 AM
Hybrid-Fusion's Avatar
Default Re: Removing axles during swap (kinkyintegra)
I've never seen it done that way, but it seems like a hassle. It should only take 10-15 minutes per side to pull an axle.
Old Jan 12, 2007 | 08:22 AM
SkoundrelUSA's Avatar
cute little bastard
Why not just pull them out? Not that hard. You gotta do like 75% of removing the axle anyway
Old Jan 12, 2007 | 08:28 AM
slwburn's Avatar
Default Re: Removing axles during swap (SkoundrelUSA)
As above - like alot of things. It might seem like alot of work to do it right... but in the end its actually less work.
Old Jan 12, 2007 | 08:54 AM
EGHatchback.com's Avatar
agree with slwburn...
i think there are only two bolts on each side you have to remove to get your hub assembly to swing out... besides the big dog
Old Jan 12, 2007 | 10:42 AM
Jinako's Avatar
Default Re: (EGHatchback.com)
I usually get the 17mm bolt and the 17mm safe nut on the bottom out and then just use a screwdriver to pry out the axle on each side from the motor/tranny. Works everytime.
Old Jan 12, 2007 | 10:47 AM
fmrprojects's Avatar
Default Re: (Jinako)
taking out the axles will help remove the motor a lot easier. i always pull it form the top and always never had a problem with clearance issues
Old Jan 12, 2007 | 11:52 AM
poison's Avatar
Default Re: (fmrprojects)
Do yourself a favor and remove them..
nicky352
Jan 19, 2011 07:38 AM
Alexs S2K
12
Aug 14, 2006 12:46 PM
Capt. Jimbo McSubipants
Sep 15, 2005 11:26 AM
NACvicSi
Jul 6, 2005 07:45 AM
Lei Siew Long
Aug 14, 2001 11:55 AM
