205 tire on 7.5" wheel?
Will a 205 tire work on a 7.5" wide wheel? Will it look normal or will it be all stretched and distorted. Any info or advice would be appriciated. Thanks in advance.
Not enough information to answer. It depends on the diameter of the wheel, the size of the tire, and the type (brand and model) of the tire. That width is perfect for some wheels/tires, will look stretched on others.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostjunkieee »</TD></TR><TR><TD CLASS="quote">Yes the wheel is 17x7.5 and the tire is 205/40/17, Yokohama Parada's.</TD></TR></TABLE>
Yokohama approves that size of its Parada Spec2 tires for rims 7.0-8.0 inches wide. On 17x7.5, it should look perfect! Of course, it will still perform like crap. Get tires that perform better (like the Kumho Ecsta SPT, Yokohama ES100, etc)...
(Note - Yokohama is phasing out the Parada Spec2, probably because their performance is so much worse than their own, similarly-priced ES100.)
EDIT: Added three sentences after the original two. (Thanks, HondaF1Fanatic!)
Modified by nsxtasy at 6:39 PM 1/12/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote">
The baby Jesus cries when someone runs Parada Spec2 tires, how about some Kumho Ecsta SPTs so you can save money and get a better tire?!?!? I would've thought you would've set this young man on the right path already nsxtasy.
Jon
Jon
haha, thanks for the help guys. I **** canned the Parada Spec2's and picked up a set of Yokohama a520's. They look to be a much better tire.
BTW how long does this h-t trial user period last for?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostjunkieee »</TD></TR><TR><TD CLASS="quote">haha, thanks for the help guys. I **** canned the Parada Spec2's and picked up a set of Yokohama a520's. They look to be a much better tire.</TD></TR></TABLE>
It's not. The A520 is another crappy tire.
Yokohama makes a very good budget performance tire, the ES100. The Kumho Ecsta SPT is another excellent tire in this category.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsi00 »</TD></TR><TR><TD CLASS="quote">it will look fine because the falkens run wider than most tires...</TD></TR></TABLE>
Although 15x7 works better for the 205/50-15 Azenis.
Most other 205/50-15 tires work best on 15x6.5 and still pretty well on 15x6.
[QUOTE=boostjunkieee]haha, thanks for the help guys. I **** canned the Parada Spec2's and picked up a set of Yokohama a520's.
what model yokohama is it that you have??/ is it the old A520 directional tread???
ITR3189
Nov 9, 2007 12:34 PM
djnikko
Mar 24, 2005 03:13 PM
Hell no. That will look horrible.
