manley/ferrea valve springs, retainers and valves vs skunk2 ones
Old Jan 12, 2007 | 03:25 AM
xQB21x's Avatar
Default manley/ferrea valve springs, retainers and valves vs skunk2 ones
the price looks pretty the same. but what is better - manley (maybe ferrea) valves, valve springs and retainers or skunk2 valvetrain set? what would you choose? thanks.
Old Jan 12, 2007 | 08:39 AM
Rocket's Avatar
Default Re: manley/ferrea valve springs, retainers and valves vs skunk2 ones (xQB21x)
I would choose a valve spring, retainer, and valve seat system that is very tight fitting to prevent dynamic wobblng (provided that the spring pressure is to your liking).
Old Jan 13, 2007 | 06:40 AM
aziz93's Avatar
Default Re: manley/ferrea valve springs, retainers and valves vs skunk2 ones (Don Lackey)
^^^^^^^ thats a given^^^^^^^i think all them have worked good for many of people! It would be your choice on what company you want to support. But in the end i would choose what portflow, laskyracing or whoever you chose to do the work... install the valves they recommend or install the most.
good luck! if you want i have brand new skunk2 valves for sale standard/hi comp, b-series vtec
http://www.importreview.com/re....html this guy has a comparison of some well-known valve springs...and info on purchasing them!
Don Lackey has some of the same info with different springs
https://honda-tech.com/zerothread?id=1803606
Choose your springs wisely when you get them without cams! You dont want a weak small spring with big cams and vise versa. Also some oversized valves should not be use with certain cams. So pick your cams and go from there.
Modified by aziz93 at 11:43 AM 1/13/2007
Old Jan 13, 2007 | 08:10 AM
xQB21x's Avatar
aren't they all tightfitting? which ones would you choose?
Muckman
Feb 24, 2012 10:43 AM
smnowell
82
Jan 24, 2011 11:52 PM
SupraManAG
Feb 15, 2008 08:48 PM
turbodohcsi
Jul 27, 2006 02:16 AM
andrewasf77
Feb 24, 2004 06:47 AM
