How much could I get for a 5-th gen "manual swap kit" ?
How much could I get for a 5th gen complete manual swap without the tranny? And I mean everything I’ll even include the shift ****/boot. Here are the parts included:
Trans mounts-side
Engine Mount-rear
Flywheel and bolts
Clutch Kit and bolts
Clutch Master Cylinder
Clutch Slave Cylinder
Clutch Dampener
Vehicle Speed Sensor (VSS)
Reverse Switch
Hydrolic Lines
5spd Starter
Clutch Pedal Assembly
Brake Pedal Assembly
Shifter Assembly
Shift linkage
5speed ECU
5spd Intermediate shaft (half-shaft)
5spd Gauge Cluster
Cotter Pins (assorted sizes)
Assorted Nuts and Bolts
Trans mounts-side
Engine Mount-rear
Flywheel and bolts
Clutch Dampener
Reverse Switch
Hydrolic Lines
5spd Starter
Shifter Assembly
Shift linkage
5speed ECU
5spd Gauge Cluster
hi im too lazy to put some effort into finding how much all this is worth, i bet my fellow ht peeps would love to waste their time to help me figure out because im too much of a lazyass to do it myself. wow thanks ht!
I would say around $600. All because you dont have a tranny. I payed $1000 shipped for everything + tranny. $600 looks alot more affordable than $800 w/out a tranny.
xduB95preludeSi
Jul 25, 2014 12:32 AM
alpinefr3ak
Dec 11, 2007 07:03 AM
