want to swap h22 in six gen accord
please help me with all the parts i need i'm familuar with b series swapes do them all the time just tell what exactly i need to make this fit in my new ride thank you
I was doing research on this very swap and discovered you can also turbo the 4cyl that is in there and just put on h22/h23 heads. Still not sure as to a parts list for the whole thing though.
There is a whole bunch of posts on this topic. Just search and you will find it man. I have a H22A swap in my 6th gen. Most stock parts can be used, but you will need a new ECU, custom driver side motor mount and a obdII jumper. Other then that, you can use F series parts....alternator, radiator, exles, tranny, etc.
Good luck on the swap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by search »</TD></TR><TR><TD CLASS="quote">» Search Results
Your search for h22 6th returned 30 results.
^^^ All the info you need is in those results. Search the archives. I'd give you direct links but I'm not at my home computer, where I have the write-ups bookmarked.
https://honda-tech.com/zerothread?id=1181924
https://honda-tech.com/zerothread?id=689185
https://honda-tech.com/zerothread?id=473019
https://honda-tech.com/zerothread?id=1513802
All these links came from the search I mentioned... I'm not sure what else you could possibly be looking for.
1997Accord
Mar 29, 2002 01:52 AM
