ek sunroof noise
Old Jan 11, 2007 | 09:56 PM
bleedblue94's Avatar
Default ek sunroof noise
sunroof works fine ... opens and closes perfect, but when it is closed the glass is rattling . when i reach up and push the rattle stops, but its getting really annoying. has anyone had this problem before and / or fixed it. thanks
btw 98 ex
Old Jan 11, 2007 | 11:18 PM
Frozen E's Avatar
H-T White Ops
rattle or a squeak? Squeaks are normal and there was actually a recall/fix for that from the dealerships. They did one on my Si. They installed some bullshit teflon tape stuff that made the squeak go away.
Old Jan 12, 2007 | 02:19 AM
Default Re: (IslandSi)
its more like a thud to be honest
Old Jan 12, 2007 | 07:47 AM
Default Re: ek sunroof noise (bleedblue94)
sdhkm,.kgyjhd
Old Jan 12, 2007 | 05:44 PM
nobody has had this thud issue
Old Jan 12, 2007 | 06:45 PM
bpkmrtoes's Avatar
i'm not sure... but i read alot here.. and i think there were somethings that you can tighten...
Old Jan 12, 2007 | 07:18 PM
Default Re: ek sunroof noise (bpkmrtoes)
any more info? i searched all sunroof titles in this forum but none of the titles had anything near what im discribing unless i just overlooked it
Old Jan 12, 2007 | 07:28 PM
bpkmrtoes's Avatar
i have no idea... i was just trying to throw something out... if i had a sunroof i would go out and check it real close. I've read something about screws or bolts for the sunroof track.... but maybe that was for my Legend.... so i'm not sure myself... sorrie....
Old Jan 12, 2007 | 07:47 PM
robble36's Avatar
if its making a thud its obviously loose or not on the track i mean i dont have a sunroof but as you describe it.. you should check the screws on it thats all i got to say
Old Jan 12, 2007 | 08:20 PM
evolutionglitch's Avatar
my friend had a similar issue with his 'lude so we just remove the sunroof made sure everything was tight and reasembled... the noise went away almost all the way... he said that that was as good as it was going to get because the tracks and sliders just wear out...
just take it apart and tighten and lube up everything and throw it back together... you that could be the problem or you might find something when you take it apart... either way you should just take it apart and clean/tighten/lube it, unless your mechanically retarded in which case your Q? is pointless... but seriously go for it with a friend and give yourself a slap on the back when you conquer all that is sunroof!
...wait!... scratch that! go for the cf sunroof delete!... lol jk
Old Jan 12, 2007 | 10:11 PM
Default Re: ek sunroof noise (evolutionglitch)
haha yeah thanks im going to when i have some time here ..... appreciate the input i was just wondering if there is anything in particular to check ... but thatnks everyone
jfzaki
11
Dec 20, 2011 06:51 AM
Guitar333
Honda Civic (2001 - 2005)
May 21, 2010 08:25 PM
iH8RICERZ
Oct 24, 2005 10:49 AM
durt
Nov 30, 2003 03:22 PM
Chris y0!
Jan 11, 2003 11:52 PM
