will dc2 rear disc brakes fit an 89ef hatch?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by driftdas2000 »</TD></TR><TR><TD CLASS="quote">yes only changes are the toe adjusting arms and upper control arms and ebrake cables from a disc car and of course brake lines</TD></TR></TABLE>
Partially wrong....you don't need to swap your toe adjusting arms or the upper control arms these parts will stay on the car. These parts should not be taken off.
The ONLY thing you will swap is the trailing arm and e-brake cables.
you have to take the toe arm to put on the integra rear disc brakes (you have to use the civic toe arms)
didnt; know u could use dc2 brakes on a ef da brakes are cheaper thou and all u need is a 40/40 prop valve
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jerms »</TD></TR><TR><TD CLASS="quote">all u need is a 40/40 prop valve</TD></TR></TABLE> No you don't unless you are running the full Integra braking system == MC, Front and rear brakes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote"> No you don't unless you are running the full Integra braking system == MC, Front and rear brakes.</TD></TR></TABLE>
Tyson established that you don't need to change it, and if you source the RR / Auto-X forum you'll show many people who run successfully without them.
mingbling96
May 6, 2006 09:55 PM
