swapping y7 intake manifold
ok i bought a d16y7 for 200 bucks, the car is 90 crx si with p05 chiped ecu, which is obd1 ecu, anyways the problem is does the motor directly fit no mods needed or do i have to do a wire harness swap becus the motor is obd2 or distributor and my ecu is obd1 help would be appreciated thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fin781 »</TD></TR><TR><TD CLASS="quote">ok i bought a d16y7 for 200 bucks, the car is 90 crx si with p05 chiped ecu, which is obd1 ecu, anyways the problem is does the motor directly fit no mods needed or do i have to do a wire harness swap becus the motor is obd2 or distributor and my ecu is obd1 help would be appreciated thanks</TD></TR></TABLE>
well id have to say is drop the y7 in there and use your existing dizzy intake manifold and what not on the y7 easier and saves time
