how to visually make sure vtec is working?
want to how to check it. just got into the honda game so im not really sure if its popping.had an lsvtec built for me and the felt strong all the way to the 7500 redline(some ebay chipped p28). then later on it felt a little weaker up top and could really tell if vtec was popping.
setup
b18b
b16 head
ITR cams
ITR intake manifold
dual valve springs and retainers
type r valves
ds 4-2-1
2.25 piping on a stock muffler with no resonator
Modified by ecksman at 7:16 PM 1/12/2007
setup
b18b
b16 head
ITR cams
ITR intake manifold
type r valves
ds 4-2-1
Install a light on the vtec trip wire.....given thats not 100%, but its 98% proof positive that if the ECU sends that signal, it will engage. Chances are its engaging though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 »</TD></TR><TR><TD CLASS="quote">One more thing... If you're low on oil, vtec won't engage so check that first.
If you're low on "oil pressure" then it wont engage.....low oil has nothing to do with it. I've been 3.5qts low and the **** still engaged just fine. Either way, vtec is A4 on the ecu pinout.
http://www.b18c5eg.com/obd1.jpg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ecksman »</TD></TR><TR><TD CLASS="quote">i mean with some sort of test for example a test light, micrometer. if so what do i check? one cel but i think vtec was popping with cel before.</TD></TR></TABLE>
How the hell can you measure vtec with a micrometer?
If you have an oil pressure guage you can hook that up to... hmm damn where did I do it on mine again. Fack. Anyway where it a location on or near the solenoid you can tap into and when you get to vtec crossover you'll notice the oil pressure guage spike up. Should give a definite sign it's working. That and you should hear the cross over too.
-RIk
-RIk
just realised today that when i first turn on the car and let it warm up a little vtec pops fine, but after i drive it for a bit it wont pop anymore. dont know what it could be. only have 1 CEL according to the guy who put it all together for me which he also told is due to the fact that he couldn't get the O2 off my stock headers so he used one that was bad to plug up the bung. u think maybe a CEL is turning up after driving the and its going ino linp mode, if not what else could it be?
jkrak
Nov 21, 2012 01:50 AM
Jimster480
17
Jul 27, 2010 12:39 PM
05r1
16
May 20, 2005 08:21 AM
