TRANNY PROBLEM HELP!!!!!!!!!!!!!!!!!!!
Old Jan 11, 2007 | 07:51 PM
sdboostin111's Avatar
Default TRANNY PROBLEM HELP!!!!!!!!!!!!!!!!!!!
OK I HAVE A EF SWAPPED WITH A SOHC ZC I SPUN THE ROD ON MY OLD ZC BLOCK SO I BOUGHT A LONGBLOCK SOHC ZC BUT IT WAS THE CARBURATED ONE,SO ONLY THING I BASICALLY DID WAS SWAP SHORT BLOCKS.WHILE I SWAPPED THE BLOCKS I DECIDED TO CHANGE THE CLUTH SO I BOUGHT A NEW CLUTCH FOR THE MOTOR,BEARING,FLYWHEEL,ETC ,NOW MY PEDAL GOES ALL THE WAY TO THE FLOOR WITH THE ADJUSTMENT ALL THE WAY UP.ITS A SI TRANNY I TOOK IT APART AND I NOTICED THE BEARING WASNT EVEN HITTING THE CLUTCH WHEN ENGAGED ,I WANTED TO KNOW WAT MY PROBLEM IS,OR IF THEY MAKE A LONGER THROW OUT BEARING JUST SO THE CLUTCH WILL HIT IT WHEN ENGAGED????????SOMEONE PLZZ HELP IM SERIOUSLY STREESIN
Old Jan 12, 2007 | 05:19 AM
plzzz help
Old Jan 12, 2007 | 10:44 AM
anyone?
Old Jan 16, 2007 | 10:44 AM
hello
Old Jan 16, 2007 | 11:36 AM
Honda Bull's Avatar
Default Re: (sdboostin111)
Is there anything physically different in any of the parts you replaced from the previous ones that worked?
QuarterMileMaster
Jul 24, 2007 12:51 PM
greenzchatch
12
Dec 26, 2006 03:31 PM
sdboostin111
Dec 3, 2006 10:21 AM
NewtoHonda
Jan 31, 2006 07:59 PM
Phat_GSR
Jan 5, 2003 02:21 PM
