Car wants to sputter or skip right as i start to accelerate cant figure out???
Old Jan 11, 2007 | 06:01 PM
crackerjacker006's Avatar
Default Car wants to sputter or skip right as i start to accelerate cant figure out???
First of all i have a 99 civic ex w/ gsr swap(running obd1). Im using a stock b18c mani but the throttle body came from a different gsr and the tps has been changed. The problem is when i start to give it a little throttle it misses just once like it isnt getting fuel for a split second and it does it every time i let off the throttle all the way and give it gas again. I have changed the tps and adjusted but have had no luck and also it does not throw a code. Does anyone have any possible suggestions?
Old Jan 11, 2007 | 06:08 PM
gezzuzz's Avatar
Default Re: Car wants to sputter or skip right as i start to accelerate cant figure out??? (carjacker006)
did you calibrate you tps? with a volt meter?
Old Jan 11, 2007 | 07:56 PM
Default Re: Car wants to sputter or skip right as i start to accelerate cant figure out??? (gezzuzz)
no i haven't, im trying to get a throttle body with an untouched tps do you think this could fix the problem
Old Jan 11, 2007 | 08:02 PM
gezzuzz's Avatar
try it.. if thats the problem i will tell you a quick way to calibrate it
UKintegra
Jun 8, 2011 12:32 PM
TonyRomo
Dec 27, 2008 03:13 PM
philosofy1
Jan 10, 2007 07:46 PM
zccr-xsi
13
Feb 5, 2005 07:59 PM
