pilot bearing into flywheel problem
Old Jan 11, 2007 | 05:52 PM
numbnuts22715's Avatar
Default pilot bearing into flywheel problem
I bought a new ACT XTSS clutch kit, along with a Fidanza flywheel, and The pilot bearing will not fit inside. Is there anything I need to do to fix this problem? I do not know all of the details because Im not in the same city as my car, so my parents have been relaying the messages to me from the mechanics. I would have installed this myself, but since my engine is getting replaced under warranty, and the clutch needs replaced too, they said they would install it for free.
Thanks in advance.
Old Jan 11, 2007 | 06:15 PM
immalooser's Avatar
Default Re: pilot bearing into flywheel problem (numbnuts22715)
you need to make sure you are fitting it through the right side. It will go in on one side only.
Old Jan 11, 2007 | 06:21 PM
RS'R''s Avatar
find a closed socket wrench size that fits perfectly over the bearing -- then knock it in with a hammer. and yes -- it only goes in one side
Old Jan 11, 2007 | 08:12 PM
95 integra's Avatar
Default Re: (RS'R')
Its a PITA....generally its easier if you cool the bearing and heat the flywheel....then beat it with a large hammer and hope you dont f it up in the process. Or you can get a press/take it to a shop with a press and rock that out.
Old Jan 11, 2007 | 08:14 PM
Default Re: (95 integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">Its a PITA....generally its easier if you cool the bearing and heat the flywheel....then beat it with a large hammer and hope you dont f it up in the process. Or you can get a press/take it to a shop with a press and rock that out.</TD></TR></TABLE>
It's at the shop now. Supposedly the mechanic told my dad it's about 2 mm too big for the hole. Would it hurt anything if he pressed it in? does the bearing need to be able to move or anything of that sort?
Old Jan 11, 2007 | 08:27 PM
95 integra's Avatar
Default Re: (numbnuts22715)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 &raquo;</TD></TR><TR><TD CLASS="quote">
It's at the shop now. Supposedly the mechanic told my dad it's about 2 mm too big for the hole. Would it hurt anything if he pressed it in? does the bearing need to be able to move or anything of that sort?</TD></TR></TABLE>
If its 2mm too big, then its not right, but generally they are extremely tight. You wont be able to press that in and its not suppose to move....either way, get the right bearing.
Old Jan 12, 2007 | 09:57 AM
Is it okay to put the pilot bearing into the backside of the flywheel?
Just making sureee
Old Jan 12, 2007 | 12:05 PM
nitrofish420's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 &raquo;</TD></TR><TR><TD CLASS="quote">Is it okay to put the pilot bearing into the backside of the flywheel?
Just making sureee</TD></TR></TABLE>
That's the only way you can press it in. It's got a ledge on the front side that it bottoms out on when pressed in from the rear.
D16SiHatch
Apr 2, 2008 02:13 PM
The Flying Dutchmen
Sep 9, 2007 09:34 AM
95LssTeg
May 28, 2006 07:09 AM
1fastVX
Aug 22, 2002 05:43 PM
