99-00 Civic SI Strut Bar on 99-00 Hatch?
Old Jan 11, 2007 | 04:50 PM
djmatix's Avatar
Default 99-00 Civic SI Strut Bar on 99-00 Hatch?
I've done a couple of searches but cant find the answer. I just picked up an SI bar for a good price and I want to mount it to the ole' EK hatch. I see that there are marks in the metal where it would go if it were an SI.
Does anyone know the part number from honda, or where I can find the proper hardware to mount this bar? Any help would be greatly appreciated.
Old Jan 11, 2007 | 04:55 PM
I Shot 50 Cent's Avatar
I ran a search but couldn't find anything other than the part numbers for the bolts themselves.
So I PM'd the guy asking where he gets his part numbers from and directed him to this thread. He was actually "online" so hopefully he'll reply here with some useful information.
Good luck man.
Old Jan 11, 2007 | 05:00 PM
djmatix's Avatar
whoa, thanks a lot! I appreciate you taking the time to do that for me. I'll keep you posted.
Old Jan 11, 2007 | 05:04 PM
Default Re: (djmatix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djmatix &raquo;</TD></TR><TR><TD CLASS="quote">whoa, thanks a lot! I appreciate you taking the time to do that for me. I'll keep you posted.</TD></TR></TABLE>
No problem man...many have forgotten that the whole reason we're all here in the first place is to get, and give helpful information.
I'll let you know if he responds to my PM with anything.
Old Jan 11, 2007 | 05:41 PM
I Shot 50 Cent (1:53 AM 1/12/2007): I noticed in a thread from last year, you helped someone out with the Honda Part Number for strut bar bolts. If you dont mind...where do you get your part numbers from? Is there a site you use for reference?
I Shot 50 Cent (1:54 AM 1/12/2007): Basically...I'm trying to help the guy in this thread out a little bit...but you may have the knowledge he's looking for.
https://honda-tech.com/zerothread/1861496
Try2Live4God (2:37 AM 1/12/2007): do u know what year SI he got it off of?
I Shot 50 Cent (2:37 AM 1/12/2007): Oh...99-00 Si's have different p/n's? I did not know that.
This has been the PM convo. Feel free to PM him so you can get some better help than you're getting from me. Good luck man.
Old Jan 11, 2007 | 05:43 PM
Eran's Avatar
HT White Ops
There is no bolts, by the way. They're studs that are welded to the chassis. I just used some grade 8 bolts from Tacoma Screw.
BlueIntegraBoy's Avatar
Default Re: 99-00 Civic SI Strut Bar on 99-00 Hatch? (djmatix)
All you need to do is drill out those indentations and buy 4 bolts, 8 washers, and 4 nuts from a hardware store.
Old Jan 11, 2007 | 05:52 PM
Try2Live4God's Avatar
Default Re: (I Shot 50 Cent)
If all you need are the nuts, it should be the same from the integra. It's #7 in the diagram.
The part # is 94050-08070
Old Jan 11, 2007 | 05:53 PM
Default Re: (Try2Live4God)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Try2Live4God &raquo;</TD></TR><TR><TD CLASS="quote">
If all you need are the bolts, it should be the same from the integra. It's #7 in the diagram.
The part # is 94050-08070</TD></TR></TABLE>
Thanks for coming to the rescue man, I really appreciate it.
Old Jan 11, 2007 | 05:54 PM
By the way....they're 8mm nuts....
Old Jan 11, 2007 | 05:59 PM
Eran's Avatar
HT White Ops
You mean nuts?
Old Jan 11, 2007 | 06:00 PM
I was actually under the impression that the original poster needed the part number for the Strut Bar itself, not the nuts.
Iunno, haha.
Old Jan 11, 2007 | 06:01 PM
turnsignalandy's Avatar
Default Re: (Eran)
tell us if you feel a difference!!
Old Jan 11, 2007 | 06:02 PM
Default Re: (turnsignalandy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy &raquo;</TD></TR><TR><TD CLASS="quote">tell us if you feel a difference!!</TD></TR></TABLE>
Your sig is great! Although, Miatas have great potential, and generally dominate at the local Autocross.
Old Jan 11, 2007 | 06:08 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Shot 50 Cent &raquo;</TD></TR><TR><TD CLASS="quote">I was actually under the impression that the original poster needed the part number for the Strut Bar itself, not the nuts.
Iunno, haha. </TD></TR></TABLE>
He already has the bar. He needs nuts and bolts. Unfortuantely, there are no stock bolts, since they are studs welded on. He just needs to go get some grade 8 hardware.
Old Jan 11, 2007 | 06:15 PM
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">
He already has the bar. He needs nuts and bolts. Unfortuantely, there are no stock bolts, since they are studs welded on. He just needs to go get some grade 8 hardware.</TD></TR></TABLE>
Reading owned me that time. I swear I read that post like 4 times and I didnt pick up on him saying he already purchased the bar, you are correct. Thanks for clearing that up man.
Old Jan 12, 2007 | 03:48 PM
djmatix's Avatar
thanks for the help guys. Somewhere someone said that there are special bolts with "figure 8" clips that mount from the bottom to help distribute the weight. Maybe he was nuts, or they were parts from comptech. Thanks for all the help. I guess i'll hit the hardware store for some high grade bolts, washers, and nuts.
Old Jan 12, 2007 | 05:03 PM
BrakeExpert's Avatar
Old, dirty pic, I apologize JDM junkies.
Look closely at where the tower bar mounts. This is a Type-R style tower bar, but same idea and same mounting. I have a 96 civic sedan, same issue you had (IM is not stock.) I put the bar about where it goes. only one of the holes on each side might line up (thats how I had it.) Drill into the frame first with a 1/4" drill bit (use oil, this can get hot) and step it up to the bit that is just bigger than the bolt you use. Since you do not have studs...what I did is call comptech. 18$ for a pair of these two bolt studs welded to this thin *** metal bar. you drill the holes and slide this bar that looked like a wide "U" and it goes through the frame. put the bar over it and use those bolts (part #7 as that guy said) and that will attach it. I dont know what a figure 8 clip is. Search the archives in the EK/EG forum for 'civic tower bar' and there is an old DIY in there with a bit more info.
PLEASE NOTE!!! If you have the stock engine, the D16Y7, and you have a totally stock intake, that plastic box will be in the way and the 99 Si tower bar will not work.
Old Jan 12, 2007 | 06:15 PM
bmoua's Avatar
Default Re: 99-00 Civic SI Strut Bar on 99-00 Hatch? (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">All you need to do is drill out those indentations and buy 4 bolts, 8 washers, and 4 nuts from a hardware store.</TD></TR></TABLE>
yep... i used a gsr/si strut bar bar on my EJ8...
94_civicEx
Feb 27, 2007 05:31 PM
Mikes2000civicsi
Nov 13, 2006 01:50 PM
Turboed00EM1
Sep 5, 2006 06:10 AM
5STAR3
Aug 16, 2002 09:52 PM
