preloaad shim
Old Jan 11, 2007 | 04:01 PM
97tnsir's Avatar
Default preloaad shim
Hey guys,
I need to know what preload shim to get for my ITR tranny rebuild.The last one was ate up when the bearing binded from the preload not being performed correctly(not by me). Now that I have a new diff and bearings, I need to know what size shim. I know I will probably 2 or 3 to find the right size, but at $8 a pop, I don't want to order a bunch.
Specs: 98 ITR 4.785 fd oem LSD
Old Jan 11, 2007 | 10:33 PM
97tnsir's Avatar
Default Re: preloaad shim (97tnsir)
bump, someone has to know this. Help
Old Jan 12, 2007 | 03:55 PM
97tnsir's Avatar
Help. Any help is appreciated. Help
Old Jan 13, 2007 | 11:47 PM
97tnsir's Avatar
bump
Old Jan 17, 2007 | 08:23 PM
97tnsir's Avatar
What the expletive. This is lame.
I thought this was Honda TECH.
I guess I'll go find the answer at Hondaswap
Old Jan 18, 2007 | 06:54 AM
cxSHOE's Avatar
inorder to find out what size shim you need, you need to measure the differential gap then add the necessary shims to fall within the gap range.
to find out the range you can either go to your dealer as the parts guy to copy the shim gap page, then get yourself some angled feeler gauges, measure it , find gap then buy necessary shims, then install.
Old Jan 18, 2007 | 07:12 AM
walker111's Avatar
Default Re: preloaad shim (cxSHOE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE &raquo;</TD></TR><TR><TD CLASS="quote">inorder to find out what size shim you need, you need to measure the differential gap then add the necessary shims to fall within the gap range.
to find out the range you can either go to your dealer as the parts guy to copy the shim gap page, then get yourself some angled feeler gauges, measure it , find gap then buy necessary shims, then install.</TD></TR></TABLE>
Or we can just guess if that makes you feel better, afterall, it is honda TECH, we'd probably be right!
Old Jan 18, 2007 | 08:31 AM
GO-FIGHT-KILL's Avatar
Default Re: (97tnsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97tnsir &raquo;</TD></TR><TR><TD CLASS="quote">What the expletive. This is lame.
I guess I'll go find the answer at Hondaswap</TD></TR></TABLE>
Calm down there Johnny Cash... God forbid you don't get your answer right away. Oh, and there's no "bumping" in the Type-R section.
Old Jan 18, 2007 | 10:02 AM
neo_'s Avatar
Default Re: (GO-FIGHT-KILL)
I didn't use no damn shims when I rebuilt my transmission.
Old Jan 18, 2007 | 11:44 AM
97tnsir's Avatar
Default Re: (neo_)
Sorry guys, just haven't driven my car in <U>too</U> long. The dealer gave me the impression that it was within a couple of certain sizes.
Thank you for your responses.
Hey neo, how much will you charge me to put my tranny back together? jk
Thanks again,seriously.
k20powered
Honda Civic (2006 - 2015)
Jul 27, 2008 05:33 AM
UMGixxer6
Honda Motorcycles
Oct 19, 2005 10:50 AM
chihuahuamanx
Feb 4, 2005 11:53 AM
Nuts
Jun 15, 2004 05:38 AM
